Old 08-04-2021, 12:53 AM   #1
Bob Q
‘81-‘87 4x4 Transmission tunnels
I noticed that our ‘84 K2500 with the factory SM465 has a one-piece solid transmission tunnel where as the ‘83 has the older style bolted/removable type tunnel (both are 4x4s with SM465s and high hump tunnels). Does anyone know if the transmission tunnels are the same shape between the bolted style and solid type? We were thinking of cutting out the tunnel on the ‘84 and fitting the older bolted style cover in its place. Anyone done this before?
Thanks.
Bob Q.
'83 K2500 6.2L
Bob Q is offline   Reply With Quote
Old 08-04-2021, 11:08 AM   #2
kipps
Re: ‘81-‘87 4x4 Transmission tunnels
I've definitely heard of it being done, but haven't done so myself. My 1987 manual-trans v20 has a non-removable hump. I've wondered about purchasing a removable hump from the junkyard and bolting it in. It would make transmission service a bit easier. It's possible the cab would lose some rigidity though.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 08-04-2021, 12:25 PM   #3
44th Miss Inf
The floor shape is just a bit different when they changed to the solid floor, but not a lot. The 81-83 bolt in is closer than the 73-80, but either are not that hard to fit.
44th Miss Inf is offline   Reply With Quote
Old 08-04-2021, 12:29 PM   #4
kipps
Where does the np208 shifter attach on a removable hump floor? Is it bolted to the hump, or to the floor behind the hump?
Old 08-04-2021, 12:45 PM   #5
44th Miss Inf
Removable section (this came out of my 82, and has been modified for an NV4500, by cutting offset and turning the piece around that goes around the shift tower, thereby retaining the original shifter boot)
Old 08-04-2021, 02:40 PM   #6
Bob Q
Thanks guys. I think we’ll go ahead and cut it out to use the removable cover.
Old 08-04-2021, 02:46 PM   #7
44th Miss Inf
Here is one i have from an 80 K30. It had a np205 case. Its a little different, as the removable portion of the hump isnt quite as long as the 81-83
Old 08-05-2021, 11:32 AM   #8
SunSoaked
SunSoaked's Avatar
So on the perimeter of the removable section, does it line up and sit flush with the floorboard or does it require some reshaping of the edges to match up? Are there big gaps that require loads of sealant to close?
SunSoaked is offline   Reply With Quote
Old 08-12-2021, 12:36 PM   #9
jdmaffeo
jdmaffeo's Avatar
My '84 2-wheel drive has the higher non removable hump since it is a manual truck. Plenty of room for any transmission that I want. I've test fitted with a 6L80e and I have plenty of room all the way around.
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop.
jdmaffeo is offline   Reply With Quote
Old 08-13-2021, 03:57 PM   #10
Honest Bob
Honest Bob's Avatar
I did this on my 75 2wd cab. I just cut out the hole and put a cover back in and used nutserts for the bolt holes. You will need the little hump piece to meet up with the rear of the cover that 44th Miss Inf pictured. Otherwise the cover fits great in the front and sides.
Honest Bob is offline   Reply With Quote
