Old 08-14-2021, 03:47 PM   #1
HTX86chevy
HTX86chevy's Avatar
engine bogs under load
have an 84c10 with 5.3/4l60e swap DBC
truck bogs down under acceleration. idles fine but will only speed up gradually and falls flat when I step on it. fuel pressure is steady at 58psi
things I have changed:
MAF
Fuel pump
fuel regulator
throttle body
fuel filter
complete wiring harness
codes that just popped up recently are:
p0107 manifold absolute pressure/ barometric pressure circuit low
p0342 camshaft position sensor A circuit low bank 1 or signal sensor
p0740 torque converter clutch circuit/open
p0753 shift solenoid A electrical
p0758 shift solenoid B electrical
what would you guys check 1st?
HTX86chevy is offline   Reply With Quote
Old 08-14-2021, 05:27 PM   #2
Davidf
Re: engine bogs under load
The map sensor
Davidf is offline   Reply With Quote
Old 08-17-2021, 09:34 AM   #3
clay68c10
clay68c10's Avatar
I'd be looking if there is a circuit common to all those sensors.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-18-2021, 11:06 PM   #4
lutronjim
Gm has specific instuctions on how and where the map sensor is located.
lutronjim is offline   Reply With Quote
Old 08-19-2021, 11:44 AM   #5
Custom 68
Custom 68's Avatar
I had some issues long ago and it was tied to a blown fuse. It wasn't like a group of coil packs or anything but enough to cause similar issues. Start there with the simple stuff. or even a loose ground.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
