Old 08-19-2021, 06:40 PM   #1
landarts
landarts
69 K20 Fire Truck
Picked up the 1969 K20 long bed step side truck with service bed out of Washington. The truck was retired from the Quincy Washington Fire Department in 1998 so the story goes. Everything on this truck is original except for the altered factory bumper on the front and added diamond plate bumper in the rear. The truck at some point was painted white over the fire department red color shows underneath.
The truck is very straight as the body and grill goes. No rust to repair and only a few very small dings here and there on the body. Has a 350 V8 with 4 speed transmission with Dualmatic locking hubs on front. Mileage on truck says 11744 not sure or saying that is original or not. Will need to do the forensics on this to determine. One thing that points toward that direction is the wear and tear on the pedal pads. Another in the other direction is that the seat cover is not original. One way or the other it does not matter to me.
Cant wait to get started this truck needs to be driven and not sitting in a field for another twenty years. Might need to sell a few of the other K20's and K10's I have in storage to get this one to the front of the line. Lots of research to be done on this one. Love to know the backstory.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 08-19-2021, 07:44 PM   #2
yuccales
yuccales's Avatar
Re: 69 K20 Fire Truck
Awesome! Gun rack in a fire rig, love it!
yuccales is offline   Reply With Quote
Old 08-19-2021, 08:15 PM   #3
landarts
landarts
Yes I thought the same thing. I would imagine who ever bought it in 98 at auction and painted it white, probably installed the gun rack.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 08-20-2021, 12:41 PM   #4
Caddylackn
Caddylackn's Avatar
Probably for the Polanski axes. Fireman's best friend.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 08-19-2021, 10:31 PM   #5
palallin
Oh, my! Outstanding truck! Pics under the hood when you get a chance?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-20-2021, 11:33 AM   #6
landarts
landarts
Here are a few pictures of under the hood. When I bought it the air cleaner assembly was on the passenger floor board. The engine bay and engine is covered in dirt, dust, chicken feathers and bird droppings.
I went over to storage about a week after I purchased it to see if I could get the old girl started. Checked all fluids, hooked up a battery, added a new coil since it was missing. Disconnected the fuel lines since not sure if the lines are clogged or full of bad gas. put a little marvel Mystery oil in a squirt bottle and filled the bottle with gasoline. Squirted some down the carburetor and when I turned the key it fired right up and held an idle. Very surprised, however there is a valve or lifter sticking. I went back a few days later with a blower, Brake Kleen, a few brushes and items to clean up the motor around the valve covers so I could pull them off and see if there was anything visual I could see that might be causing the noise. I was surprised how clean it was under the valve covers compared to the gunk on the outside.
If you guys have any ideas a good way to fix or diagnose the issue I would love to hear about it.
Here is a link to the video of the truck running. https://youtu.be/Ffxs7gAwTeU
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 08-20-2021, 01:55 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
It just needs a Unity Cop Spot in the driver's side A Pillar.
Old 08-21-2021, 06:37 PM   #8
'68OrangeSunshine
Looks like it had one once. I see a 1/2'' hole in the Driver's A Pillar.
Unity is still in business in Chicago, and P/N 202 is the number of the [LH] front mount accessory for 67-72 GM trucks.
Old 08-23-2021, 08:23 AM   #9
landarts
landarts
Originally Posted by Joesjunk View Post
I just had a 1960 Impala I bought that had been sitting for 35 years. Fired right up and ran just fine. It had a pretty good lifter tick in it. I just let it run with fresh oil ( and also some zinc additives) in it and after about 15-20 minutes of running it slowly went away. That car ran like a champ and hasn’t ever made a lifter noise again.
That is great to hear and I think I will give it a try. Just ordered up some Risoline with zinc. Thanks for the suggestion.
Have not noticed that but if there is a hole already then it will be getting a spotlight. Thanks for the mentioning of that.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 08-20-2021, 05:59 AM   #10
It's great for an ex-fire rig as far as not a lot of equipment mounted creating a zillion holes. I love the side bins on the Stepside. Even cooler than a utility bed.
Old 08-20-2021, 01:58 PM   #11
57taskforce
All about them K’s
57taskforce's Avatar
Pull the valve covers off and push down on all the rockers one at a time when the rockers are relaxed(tdc on each cylinder). If it’s a collapsed or not primed lifter you should be able to tell which one it is. Might be as simple as a rocker or two that are backed off. You can take a dead blow hammer or rubber mallet and smack the valves one at time when the rockers are relaxed and check to see how free the valves move. I would bet it’s a lifter not priming up or a rocker nut that is backed off/rocker stud that is loose or pulled.
Tyler
Old 08-20-2021, 05:05 PM   #12
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I like it, nice find!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-21-2021, 07:05 AM   #13
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice find! What a cool truck. Factory K steppers are pretty scarce!
Ryan
1969 Chevy milk truck
Old 08-21-2021, 09:38 AM   #14
Joesjunk
Joesjunk's Avatar
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 08-23-2021, 12:53 PM   #15
Dieselwrencher
I also like that 1 year only maroon interior. It would be cool to paint it back red but I know it would be a ton of work.
Ryan
Old 08-23-2021, 01:43 PM   #16
landarts
landarts
If I decide that I am going to keep this truck I might just go that direction.
If not I would probably go Maroon outside with Maroon and white interior like the picture below.
I have a crew cab build coming up next for myself.
So really not sure if I will be keeping any of the six K20's that I have or sell a few so I can concentrate on K20 Crew Cab build.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 08-23-2021, 04:05 PM   #17
Dieselwrencher
A crew cab is on my list as well. 6 K20s, you're the man!
Ryan
Old 08-23-2021, 06:45 PM   #18
Reading over again I see you said "altered factory bumper". I can see what they did but could you get some pictures next chance you get?
Old 09-01-2021, 04:40 PM   #19
landarts
landarts
Here is the best picture I have for now until I drive back over to storage lot. Looks to me that they cut of the ends and boxed it in to make a area for tools. The positive is that I will be easy to reverse with a new bumper and the bigger bonus is that it protected the grill from getting destroyed or dinged up over time. If you need any other pictures let me know.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 09-01-2021, 05:31 PM   #20
palallin
That puppy would be the bees' knees (with appropriate padding) for working under the hood.
Old 09-01-2021, 05:38 PM   #21
landarts
landarts
Actually already did that when I was trying to get it running. I threw a big folded up quilt on it and it was actually really nice when I was working on the motor.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 09-01-2021, 06:33 PM   #22
'68OrangeSunshine
With a front bumper like that, you could use it for effective power-shove parking in bigger cities. If the Prius parked in front of you too close, you just get in Granny Gear and relocate him forward a couple feet. Then you've got room to swing out.
Old 09-18-2021, 09:27 AM   #23
landarts
landarts
Trying to get back on this to find a solution to the sound that is coming from the motor. Sounds like a stuck lifter or possibly a knocking rod.
Here is a video of the truck running and the sound is easy to hear.
If any one knows how to embed video so it shows in the post please let me know.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 09-18-2021, 05:08 PM   #24
dmjlambert
dmjlambert's Avatar
I thought I knew how to do that but can't get it to work now.
Old 09-18-2021, 06:15 PM   #25
landarts
landarts
Originally Posted by dmjlambert View Post
I like everything on that truck, grill, bed, utility/toolboxes, front and back bumpers, just everything. I'd put A/C in it and make that my new daily driver if it were mine. Great find.
Yes it is a pretty solid truck and if I decide to keep it I will be installing vintage AC or an original setup that I have access to in the stash.
I thought I knew how also, I am actually a web developer and do this all the time. Must be something in the forum that is stopping it from posting.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
