08-22-2021, 01:41 PM | #1 |
Propane system documentation?
My ‘72 C20 big-block was converted to a dual-fuel propane and gasoline setup in the 1980s. It has an adapter between the air cleaner and the carb made by Independence Carburetor Systems which is no longer in business. My question is does anyone have any documentation on adjusting this system? I’m having a hell of a time trying to get my truck to run properly across the rev range.
08-24-2021, 07:33 AM | #2 |
Proprietor of Dale's Corner
Re: Propane system documentation?
I wish you luck, I'm no help. I don't have know anything about them. Have you talked to a fork lift mechanic? I would think the basics would be similar.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-24-2021, 11:30 AM | #3 |
The only documentation I have is this crude system diagram, but I have nothing on adjustments.
08-24-2021, 02:54 PM | #4 |
Maybe check on some off road forums, as alot of offroaders use this setup for the extreme angles they run on trails and rocks.. Best of luck.
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
08-24-2021, 08:40 PM | #5 |
It's been years since I worked on propane systems, but the most common problem I found was that the diaphragm in the vaporizer would tear or get so stretched that it wouldn't meter correctly. Is there a brand name on the vaporizer? Most of them were made by Impco and you should be able to find parts for that brand.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-25-2021, 01:10 PM | #6 |
Yeah, it's an Impco, but the problem started when I removed the air cleaner to fix the wire that goes from the cab to the diaphragm mechanism in the adapter, something with the adjustment bolt in the top of the air cleaner.
08-25-2021, 01:29 PM | #7 |
What size Impco? If its a 425, that is only rated up to about 300 hp. You say this is a big block? It probably is not big enough to support your horsepower so I would imagine its running out of fuel at higher rpms. The Impco 425 is equivalent to a 2-barrel carb for a stock V8.
https://propanedepot.ca/wp-content/u...Carburetor.pdf Watch your temperature gauge, as the motor will get hot and burn up valves if you are running it lean for long periods under load.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
08-26-2021, 02:07 PM | #8 |
Correction: It's not an Impco, but a Borg-Warner Marvel-Schebler/Tillotson (seriously, five names guys?).
08-27-2021, 09:36 AM | #9 |
Looks like same system that was on my big block truck when I bought it, and it had sat for well over 30 yrs. I never even attempted to resurrect it, and had no intent on running the truck on propane, so I removed it all, and sold the parts to someone who does propane. One thing about it, the truck only had about 62,000 miles when parked, and had been ran mostly on propane. Engine is extremely clean, and the only issue I ran into was timing gear was brittle, so I replaced (glad I checked).
