12-25-2003, 09:49 AM | #1 |
mastercyl and booster
I am making one truck out of three, I have a 72 cab I am putting on 68 frame With 67 front clip.My question is : I want to use the power brake booster and master cyl rrom the 72 with the 68 drum brakes (72 front suspension is bent) will 5this work? gonn use a stock 305 - no racing just cruising so drums should be enough. I have already shortenend the frame for a short bed, getting ready to start putting things together then I can start on body.
MERRY CHRISTMAS
72 c-10 81 c-30 67 c-10 just sittin in the woods) 70 C-10 " " " " to compleete frames 67, 70 - in woods 2002 toyota tundra. 12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker |
12-25-2003, 12:35 PM | #2 |
you will need a new master cylinder. the master cylinders are different from drum/drum to disc/drum. the prop valve is different also.
70 longbed 496/th400/Ford 9" |
12-25-2003, 03:04 PM | #3 |
Try spinnin 4 rear tars
The brake booster will be just fine, but you will need a new master cylinder (Just like dinnut said).
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
