Old 08-28-2021, 10:34 AM   #1
Bandit130
Bandit130's Avatar
In-windshield radio antenna reception boost
Wanting to find something that will boost my reception. AM is especially weaker than FM. I listen to AM to and from work to get traffic reports. Don't want to add external mast antenna cause don't want to cut holes in fender or anywhere else.
Any suggestions that aren't too expensive?
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 08-28-2021, 11:12 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: In-windshield radio antenna reception boost
The longer the antenna the better the reception, and the clear air way to the station the better it will be.
Now they had some in the passed at LMC/Classic auto Parts. Check there sites.
These antennas are powered and in line at the radio ant port or the ant line the wind shield up to you space opening on your ride.
Try any radio in stall shop if there still some in your area. They can order and in stall if needed. Just about any on line radio shop.
I hope this helps.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-28-2021, 02:45 PM   #3
72c20customcamper
72c20customcamper's Avatar
Factory or aftermarket am/fm ? Reason being my 77 burban with the factory am/fm and windshield antenna sucked. Reception was terrible on both bands . Close stations came in great but hit the valleys and they would fade out.
Conversely my 85 with an aftermarket Alpine radio with the windshield antenna has great reception .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 08-28-2021, 02:49 PM   #4
Ziegelsteinfaust
What about the electronic antennas?
https://www.summitracing.com/parts/d...oaAuGkEALw_wcB
Ziegelsteinfaust is offline   Reply With Quote
Old 08-28-2021, 06:28 PM   #5
Bandit130
Bandit130's Avatar
It is a factory radio. FM works great. AM not so good at times. Radio stations are around 20 miles away from me.
Mopar by Birth
Chevy by Choice
Old 08-28-2021, 10:22 PM   #6
cadillac_al
If you travel in a hilly area it may not be the antenna. AM radio waves kinda travel in a straight line. I usually have the best reception in my windshield antenna cars.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-28-2021, 10:50 PM   #7
Bandit130
Bandit130's Avatar
No hilly areas here in the DFW area.
Mopar by Birth
Chevy by Choice
Old 08-30-2021, 07:45 AM   #8
chrismoore701
chrismoore701's Avatar
Reset the snap on the windshield. I had that issue with mine and worked 10 times better
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 09-05-2021, 11:24 AM   #9
hooverfish
hooverfish's Avatar
Can you explain, at the base of the windshield ?
I'd like to try this on mine.
Larry
84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles.
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 09-06-2021, 02:44 PM   #10
Greenlee
Greenlee's Avatar
The antenna wire from the radio snaps on to the windshield in the middle at the bottom.
Greenlee is offline   Reply With Quote
Old 09-01-2021, 05:53 PM   #11
65chevysub
65chevysub's Avatar
I have a right fender on my 84 I need to replace. If you were close, I'd see if you wanted to teade....
65chevysub is offline   Reply With Quote
Old 09-01-2021, 05:54 PM   #12
65chevysub
65chevysub's Avatar
I have a right fender on my 84 I need to replace. If you were close, I'd see if you wanted to teade....it has a factory antenna hole
Old 09-05-2021, 12:59 PM   #13
Warrens69GMC
Warrens69GMC's Avatar
https://purdylounge.com/best-car-antenna-booster/
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-06-2021, 02:42 PM   #14
Greenlee
Greenlee's Avatar
I always thought the in the windshield antenna on my 83 works surprisingly well on either AM or FM. Made me wonder why they quit using them. This is the first complaint I’ve ever seen about them.
Old 09-06-2021, 03:31 PM   #15
hatzie
Moderator
hatzie's Avatar
Generally the wire-in-glass antenna seemed to work quite well.
The windshield has a male button similar to the kind you snapped RV curtains onto in the 1970's.
The wire from the radio terminates in a jack that's screwed to the dash substructure under the centre of the dash pad.
There's a little stubby pigtail or "lead in cable" with a female snap on one end and a metal barb on the other end. The snap fits the button on the windshield and the barb plugs into the coaxial cable jack from the radio.
I have seen the little stubby pigtail that snaps onto the button on the windshield come apart or the button appear to be loose. Probably boogered up from rough handling when the glass was replaced.
Yank out the dash pad and replace what's boogered up.
lead in and antenna cable is 7 & 8 from LMC
https://www.lmctruck.com/1973-91-che...973-87-antenna
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-20-2021, 04:54 PM   #16
hooverfish
hooverfish's Avatar
Thank you both ! Appreciate the help, I will give it a try.
Larry
Old 12-24-2021, 12:29 PM   #17
hooverfish
hooverfish's Avatar
Finally got around to checking the little plug at base of windshield. The female part is broken, metal circle is partially gone, fell apart or broke off I guess.
Going to order from LMC, part #8 in the diagram.
Thanks again for the help, hatzie and Greenlee.
Larry
