Old 09-01-2021, 07:15 PM   #1
AdamH.
Help! 67 gmc k20 71 k20 cab frame mount difference
I'm not sure how to post pics. I'm going to use the 68 k frame and put a 71 body on it . (The 71 has rust issues. The frame cab supports are in same location but the hole punched in them is different. The 71 hole is punched farther back towards rear if cab. The 68 is punched basically center. I believe this and core support bracket locations will effect body panel alignment and maybe the box clearance. I'm wondering if in 71 it was wrong at the factory. Inputs please. Thanks!
AdamH. is offline   Reply With Quote
Old 09-01-2021, 07:30 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Help! 67 gmc k20 71 k20 cab frame mount difference
I’ve never heard of the cab mounts being in different locations. Interesting. How far off are they? The core support mounts are definitely different but should be in the same physical location.
Tyler
Old 09-01-2021, 09:39 PM   #3
AdamH.
The cab support holes are off 1/4 to 3/8 back.(center) The core support are in a slightly different location also. The hole size is obviously smaller on the 68 core support. I thought this stuff was the same to. Maybe just the difference in plant manufacturer location and year. Or gmc to chevy. I'm fortunate to have both frames side by side. Also someone slotted the bed mounts back some on the 71.Thanks. Anyone have a pic of k 71 frame?
Old 09-01-2021, 10:54 PM   #4
AdamH.
Re: Help! 68 gmc k20 71 k20 cab frame mount difference
Pics
Old 09-02-2021, 05:33 AM   #5
I've never seen or heard of this before. I guess it with take some mock assembly to see what's what and how things will fit. It can be remedied if there is a fitment issue, but this sure is an oddity
Old 09-02-2021, 09:01 AM   #6
AdamH.
Could someone provide me with center to center measurements from core support to cab support holes. 1969-1972 k frame. Thanks
Old 09-02-2021, 09:42 AM   #7
landarts
landarts
I can provide measurement today if you provide picture of exactly what you need.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 09-02-2021, 09:52 AM   #8
kwmech
If the measurement is off I would elongate the hole and leave everything loose until all is assembled and aligned then tighten it down. That (I think) is the only way it would look correct. Be interesting to see what's off. Both sides like that?
Old 09-02-2021, 10:58 AM   #9
AdamH.
Yes both sides. Tonight I'll take a new pic
Old 09-02-2021, 03:40 PM   #10
gmc684x4
Rad support hole size should be the only difference 68 has a smaller hole then the 69 72 trucks
Prothane had a disclaimer in there cab mount kits about this to open the hole up wider or cut the collar off the body mounts
Cab mounts themselves should be in the same actual place as the cab is the same 67 72 c10 c20 c30 k10 k20
K30 would have been a napco or diy thing
Put your cab and front clip on and test fit to the frame
gmc684x4 is offline   Reply With Quote
Old 09-02-2021, 07:17 PM   #11
AdamH.
This is the measurement I'm wanting. From center of radiator support hole to front cab hole. The 68 is about 50 5/16. The 71 is about 51 1/8. I know the angle of tape is a factor but I had it on same angle on both frames. Could someone measure there's like this and tell me what they have. Thanks
Old 09-03-2021, 12:21 AM   #12
57taskforce
All about them K’s
That is interesting, my ‘72 K20 has the holes centered like your 68. This is a couple old pictures of mine. Unfortunately I didn’t take any pictures of the front mounts specifically. As it sits my front mount bolts are more or less centered in the frame mounts.
Tyler
Old 09-03-2021, 07:12 AM   #13
I know the core support mounts are different for 67 /68 that they are for 69-72. I wonder if that is what might be making the measurement different? If you are going to use the 72 on 68 frame you may need to swap the core support brackets also. Otherwise they should be the same.
