09-09-2021, 06:55 AM | #1 |
Mismatched tire diameters...
Is there any issues with running slightly different tire heights/diameters front and rear on these trucks? I'm researching wheel/tire combos and just as a function of what I am looking for, to get the width I want the front tires are going to be 1/4 of a shorter height then the rears. Will anyone even notice besides my OCD self?
Looking at 275/40r20 in the rear which are 28.7 height and I want to run a 255 (40s) in the front which will be 29" high. If I went down to 245s I could get the exact same height, but I just want the wider tires! Any issues you guys foresee? |
09-09-2021, 07:08 AM | #2 |
Re: Mismatched tire diameters...
As long as the axles are the same size no issues. Your close to same height anyways. Normally tallest tires are in rear, at least with my experience. BTW, a 255/40x20 would be 28.1 tall by my research.
09-09-2021, 08:58 AM | #3 |
Should be fine.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
09-09-2021, 04:09 PM | #4 | |
Senior Moment
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
09-09-2021, 05:00 PM | #5 | |
https://www.tacomaworld.com/tirecalc
09-09-2021, 09:16 AM | #6 |
Beep! Beep!
I'm running 275/60/15 on the rear and 255/60/15 on the front. Those are about an 1" difference and no issues.
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
09-09-2021, 09:31 AM | #7 |
No issue at all with 2wd 4wd totally different situation as it will tear up the transfer case. Cars and trucks been running bigger rear tires for years
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
09-09-2021, 04:31 PM | #8 |
Simple math done in metric to confuse Americans!
Convert the width in mm to inches by dividing it by 25.4. There are 25.4 mm to an inch. Multiply that result by the aspect ratio. Aspect ratio is the percentage that the sidewall is to the width. That number is the sidewall height. Double that number because you have sidewall top and bottom of tire. Add that number to tire diameter. Pretty easy, eh! Try it. Tire is 255 40 20. 255 divided by 25.4 equals about 10. Times aspect ratio. 10x.40 eguals 4. Double that equals 8. Added to tire height. 8 plus 20 equals 28. You’ll be doing it without a calculator in a couple tries. Honestly likely easier to find a chart. Or go to tire rack and look for a common tire and you’ll find added tire specs that will give different dimensions. Like searching for a 275 60 15 radial t/a. |
09-09-2021, 04:58 PM | #9 |
Great lesson on the math Geezer...thanks. I do have to say that I have messed around with a couple projects tires sizes and found that the charts and equations don't really match up with reality. I even found charts that gave "loaded" and "mounted" diameters for different rim widths. The charts and such are not to be trusted to the decimal...that's for sure.
For what the OP is doing, this is not too important, but if trying to figure out speedometer gear changes, that's a different story.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
09-09-2021, 05:01 PM | #10 |
The lazy way is to use a calculator like the one on this webpage.
https://www.tciauto.com/speedometer-gear-calculator Scroll down to "Tire Diameter Calculator". |
09-09-2021, 05:14 PM | #11 |
It’s quite easy stuff!
Now, I’m still having a need to figure out the metric time conversion. That ones a little harder to do in your head. |
09-09-2021, 05:31 PM | #12 | |
Then there's the manual method of measuring out the distance the tire travels in one revolution. I did that on my truck and it came out at 26-1/4", even though the calculated diameter is 27". I used the measured diameter for selecting my speedometer gears. I tested my odometer over a 10 mile drive on the freeway, and it ended up dead on. Hopefully it will stay that way for a while, depending on how heavy my foot is. |
09-09-2021, 05:49 PM | #13 |
