![]() ![]() Join Date: Jan 2005
Question about Valve Seat Machining
I recently had a set of heads machined at a local shop. I noticed that on some of the valve seats, there is a lip at the edge of the seat where it meets the unmachined cast surface of the combustion chamber. It seems to me that ideally this would be a smooth transition instead of a lip. Is having a lip there normal and acceptable?
Re: Question about Valve Seat Machining
I would be concerned that the installed height of the valves is the same. I think the ridge is an unfortunate thing that would happen when the seat is cut deeper. That would be difficult to remove.
Hopefully the tips of the valves are cut and the shims for the springs available. I agree, those seats are cut pretty deep.
![]() Join Date: Aug 2019
How old are those heads? They don't look like they have the hardened valve seats in them. The valve job won't last long with todays gas if the seats aren't hardened.
#5 | |
![]() Join Date: Oct 2016
I'm guessing his experience with HO engines might not be perfectly representative of what a typical auto engine goes through, but he does have me reconsidering my stance on hardened seats. I'd be curious to know what experience others have had with or without hardened seats. |
![]() Join Date: Apr 2005
This could certainly be one of those back and forths, to install seats or not. As long as you are prepared for valve jobs.
I agree those look a skosh deep. At a min, I would clean up that lip. Keep any power tools away from the machined surface, but some emery cloth just to get rid of any burrs. Might be important depending on compression. These were some that I purchased from GM that were heat treated and without inserts. But I have not heard of shops with this capability and I can't intelligently speak to its effectiveness. The engine had strong springs, solid lifters and high compression and I never had an issue. Last edited by geunther; 09-16-2021 at 10:34 AM. |
From what I've read, these heads have induction hardened exhaust seats. I see vehicles in wrecking yards regularly with 300,000+ miles on this type of head.
They do look deeper than what I'm used to seeing. I wouldn't want to leave that. All of mine have always had 3 or 4 angle valve jobs, which transition into the seat angle. The same thing could be done to yours to get rid of that ridge (I think). Probably just a 75 deg cut would do it.
Seems like it would be crappy for flow, and would likely be a hot spot in there as well. |
I took these heads to another shop to get their opinion, and the guy there pointed out that the lip around the seats is not shiny, so it was machined that way by the manufacturer.
