Old 09-19-2021, 02:45 PM   #1
54blackhornet
54blackhornet's Avatar
T Fitting For Hydraulic Brake Controller ?
I have this brass fitting plumed into the front port on my master cylinder. The line exiting goes to a trail brake controller. If I unscrew the line and plug it quickly will I have to bleed the entire system ? The controller itself is starting to leak inside the cab...thanks
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 09-19-2021, 02:46 PM   #2
54blackhornet
Re: T Fitting For Hydraulic Brake Controller ?
Sorry that the photo is sideways.
71 C-20
07 Magnum RT AWD
Old 09-19-2021, 02:53 PM   #3
CastIron
CastIron's Avatar
There's one way to find out- try it. You could try bleeding it right at the fitting. Just loosen the nut while somebody pushed the pedal. I've replaced master cylinders doing that and been successful.
CastIron is offline   Reply With Quote
Old 09-19-2021, 02:58 PM   #4
HO455
HO455's Avatar
You won't have to bleed both circuits just the one that the controller is plumbed into. As a short term fix you could crimp the line to the controller to stop or slow the leak.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 09-19-2021, 03:08 PM   #5
Wrenchbender Ret
That is a flare fitting. You need a blank fitting to plug it with. The best way to get one isto take a fitting & weld it shut. I believe it is a 5/16 tube fitting. Or you could cut the tube about 2 in. from the fitting & fold it over & squese it real tight. You won't need to bleed it if you do like you say "plug it Quickly". Gravity will bleed it but don't let the master cyl run dry.
George
Wrenchbender Ret is offline   Reply With Quote
Old 09-19-2021, 04:48 PM   #6
54blackhornet
So the plug I got yesterday won’t seal it ?
71 C-20
07 Magnum RT AWD
Old 09-19-2021, 05:08 PM   #7
54blackhornet
It appears to have the proper compression flair ?
71 C-20
07 Magnum RT AWD
Old 09-19-2021, 05:46 PM   #8
Joesjunk
Joesjunk's Avatar
Take that “T” piece out and your original brake line should go right back into the master cylinder like factory. I have removed several of those and never had to bleed the brakes.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 09-19-2021, 06:18 PM   #9
Sheepdip
Sheepdip's Avatar
^^^^^^^^^^^^^^What he said^^^^^^^^^^^^^^^^^^^
That's what I did before I upgraded to disc brakes and changed the whole shebang out.
Sheepdip is offline   Reply With Quote
Old 09-19-2021, 08:53 PM   #10
pjmoreland
pjmoreland's Avatar
If you top off the master cylinder and reinstall the lid tightly prior to disconnecting the line, the fluid won't run out very quickly. That's how it's been in my experience.
pjmoreland is offline   Reply With Quote
