Old 09-21-2021, 01:07 AM   #1
ellisjay2
Thinking of going with steel braided fuel lines.....
Found this on Amazon. Figured I'd use it in replacement of rubber line from pump to filter to end of dual feed....I plant to go back plastic filter since I learned glass can break....Good idea ???? Suggestions??? What else might I need???
: Eli540
86 gmc 2500 longbed Carb 5.7, rwd,
400 tranny.
ellisjay2 is offline   Reply With Quote
Old 09-21-2021, 10:33 AM   #2
blazer2007
Re: Thinking of going with steel braided fuel lines.....
I,d stick to a good quality rubber. Didn,t Gregski have trouble with Amazon braided hose.
blazer2007 is offline   Reply With Quote
Old 09-21-2021, 11:49 AM   #3
LT7A
A lot.
LT7A is online now   Reply With Quote
Old 09-23-2021, 12:36 PM   #4
SCOTI
SCOTI's Avatar
The braiding doesn't do squat for the cheap rubber inside of it when using cheap parts.
There is a reason quality braided fuel line is expensive. It requires a high quality hose initially & then the added protection of the SS braiding on top.
Standard, current, fuel injection spec or diesel spec rubber hose works better vs standard cheap/generic 3/8" fuel hose w/o the expense or hassle of the braided cover.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-21-2021, 11:35 AM   #5
Warrens69GMC
Warrens69GMC's Avatar
your other thread-
http://67-72chevytrucks.com/vboard/s...d.php?t=826055
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
