width measurement of trim pieces help
I need to order some pinstripe ... can someone please help me out & measure how wide the cab divider & top tailgate trim are on each?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
![]() Join Date: Feb 2009
Re: width measurement of trim pieces help
Nice! Color man
![]() Thing about the cab divider is not all fit the same. When I did this one, I fit them first and marked letting them dictate the fit. The old trim was unequal on both sides. Same for the trim on my other truck, which sit +/-1/4" behind the edge of the gutter on both sides. Personally I like how these turned out, and they're equal on both sides. Using this picture, I would suggest measuring your cab choosing where you want the tape to end at the gutter. Picks of the tailgate....... Let me know if you can't zoom in, I can see the marks clearly on this end. By chance do you mean how tall? ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-27-2021 at 02:18 PM. |
If you read #2 first time, I had to correct the divider trim height, width, whatever it is
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Yes I meant how tall ... thanks so much!!!
