10-04-2021, 07:51 PM | #1 |
Under Hood Jump Box: How Does This Work?
I have what I presume is a jump box, that is under the hood of my 84 wrecker. I'm having trouble finding info about how it works; since it must serve a purpose vs just running quick connect jumper cables.
I need to draw a wiring diagram to help figure it out. It has two 12 volt batteries in series going to one solenoid and a 6 volt battery going to a solenoid on the other side. The 6 volt battery is kind of throwing me for a loop. Hopefully someone has seen one before to clue me in on how they work. Thanks
AJC |
10-04-2021, 09:01 PM | #2 |
Re: Under Hood Jump Box: How Does This Work?
Never seen anything like it....any numbers or name on it?
10-04-2021, 09:56 PM | #3 |
Not on the top or the sides. I should pull the top and see if there are any numbers inside. I know there is a light bulb inside of it that turns on with the key. Which it must be using as a load of some sort.
AJC |
10-04-2021, 11:12 PM | #4 |
Something about it makes me wonder if it's a jump box or not..
Could it be part of the wrecker part of your truck? That 12v and 6v battery sounds strange
10-05-2021, 09:23 AM | #5 |
I believe that is the control box for the flashing/emergency lights
10-05-2021, 12:54 PM | #6 |
Don't see any cables that look heavy enough to be jumper cable rated. I do see two switches and a fuse holder. Given the various batteries, could be a voltage converter to keep everything charged.
Two 12v batteries in series will give the 24V a lot of heavy duty vehicles need to start. The 6V battery could be to jump the odd ball old vehicle that is still 6V. Both are something a general purpose wrecker would need. |
10-05-2021, 09:16 PM | #7 | |
I will be at the truck tomorrow and will get more pictures of how it connects.
AJC |
10-05-2021, 01:03 PM | #8 |
It looks like a charge controller. Charges 12 or 6 volt batteries depending what you select, and can flip between the alternator charging or regular 110 household.
