Old 10-11-2021, 04:48 PM   #1
georgieb51
georgieb51's Avatar
1967 two-tone cab roof paint divide
I am trying to figure out where the white paint line breaks on the roof of my 1967 two tone cab. I know the white does not go down the A-pillar like later model trucks. I know the top iw off white and the outside drip rail is body color, but where does the paint line break? I am using the paint divider trim below the window, but I do not know where to end the white at the roof. Thanks, george As always, a photo is really what will answer my question and I have not been able to find exactly what I am looking for.
1972 Chevy Custom Deluxe Highlander, owned 34 years.
1970 GMC Sierra Grande 2500, unrestored, original.
1970 Chevy K10 Short Wide-bed, working on restoration..
1967 Chevy K10 Short Stepside, unrestored original.
1969 GMC CST (Longhorn) 396, buckets, unrestored.
1995 GMC K2500, 65,000 miles, 454.
georgieb51 is offline   Reply With Quote
Old 10-11-2021, 08:48 PM   #2
firedemon
Re: 1967 two-tone cab roof paint divide
the blue one was mine the paint line came down to door window height and stayed inside the drip rail
firedemon is offline   Reply With Quote
Old 10-11-2021, 11:56 PM   #3
chewychevy67
Here Is a good thread. https://www.67-72chevytrucks.com/vbo...d.php?t=564442
chewychevy67 is offline   Reply With Quote
Old 10-16-2021, 02:20 AM   #4
georgieb51
georgieb51's Avatar
I could still use a photo that is shot directly inot the ran gutter to see what is going on in there. This is a 67 truck. Not the later model 68-72. Thanks
Old 10-16-2021, 09:41 AM   #5
chewychevy67
This is from my 67. The inside of the rail where the seam sealer sits is ivory white and the face of the rail is body color. It is this way all the way around and ends at the paint divider under the window.
Old 10-16-2021, 10:03 AM   #6
georgieb51
georgieb51's Avatar
Thanks Chewy! This is exactly what I am looking for!
Old 10-16-2021, 10:05 AM   #7
georgieb51
georgieb51's Avatar
This also makes me wonder which color was painted first.
Old 10-16-2021, 12:42 PM   #8
chewychevy67
It looks like it would be easier to mask the vermillion poly off and spray the white after the way these pictures show. This cab just got stripped so i can't check for pant lines anymore.
Old 10-16-2021, 01:37 PM   #9
firedemon
when i stripped mine down they were painted to the center of the drip rail and the paint line had the white painted last
Old 10-16-2021, 07:10 PM   #10
georgieb51
georgieb51's Avatar
Thanks Firedemon. I think I met you once if you live in upstate NY? What you say makes sense. Then the tapers could afford to be sloppy. And if you are referring to what you saw as being an original paint job that would also make for a strong argument in your favor.
But I am still willing to listen to others chime in. I know for a fact that there is more than one way of painting the two-tone on the upper half of the doors. I have seen two original Baltimore built trucks that clearly had the whole top of the door painted white inside and out And plenty fo folks have mentioned variations in the way different factories did things.
Old 10-19-2021, 09:16 PM   #11
georgieb51
georgieb51's Avatar
After much thought I think I will paint the body color first, the roof second.
