10-15-2021, 05:10 PM | #1 |
Using van hydroboost - will van master cylinder work?
Is anyone using the master cylinder off their hydroboost donor vehicle? This came off a 2009 express 3500 van. If so... The van did not have a proportioning valve. Do still need to run one on the C10? Photo of van's master cylinder is attached
69 C10 fleetside long bed - 6.0/4l80E in progress |
10-15-2021, 05:40 PM | #2 |
Re: Using van hydroboost - will van master cylinder work?
I would say yes.
The van is a full bodied vehicle and is going to gave a lot more weight over the rear wheels than a pickup does. I would suggest an adjustable prop valve, so that you can tune what it really wants, rather than trying to match an off the shelf replacement. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-16-2021, 11:32 AM | #3 | |
All about them K’s
Hope that helps.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
02-09-2022, 12:47 PM | #4 | |
02-09-2022, 04:59 PM | #5 |
Mine did.
Discs front and rear? Or drums? The master cylinder will have a residual check valve for drums.
02-09-2022, 05:34 PM | #6 | |
I ask because from my research the newer (07ish and up) GM hydroboosters havr a different bore where the master cyl attaches
