12-27-2003, 09:08 AM | #1 |
disc brake conversion
I still would like to put disc brakes on my 67 frame. I have a 72 frame (bent). I'm about to start rebuilding my front end, will the spindles from the 72 fit the 67 ? tnere is a possibility that the A arms on the 72 are bent, so all I'd like to do is use the spindles from the disc set up. ain't got a lot of money so I can't afford yhe new set up other wise I'll juxt rebuild the drum set up.
72 c-10 81 c-30 67 c-10 just sittin in the woods) 70 C-10 " " " " to compleete frames 67, 70 - in woods 2002 toyota tundra. 12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker |
12-27-2003, 12:54 PM | #2 |
Use the 72 crossmember along with the spindles, by using the crossmember it puts the brake line connections at the correct spot for 71-72 spindles, using the 71-72 spindles you can use 67-70 A-arms but you must swap the upper and lower ball joints and all steering parts to the 71-72 style.
GMCPaul |
