10-25-2021, 12:41 PM | #1 |
Broke down in Southern Cal
I’m looking for someone who can point me in the direction of a good transmission guy I am In 29 palms but can go to Redlands San Bernardino wherever thanks for any help
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
10-25-2021, 12:53 PM | #2 |
It's Better With Nitro
Re: Broke down in Southern Cal
Von's Transmission - owner Von Neal
1904 Riverview Dr #103, San Bernardino, CA 92408 1 909-838-6581 He builds the transmissions for my hot rods.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
10-25-2021, 05:29 PM | #3 |
Thanks I found a guy in yucca valley CP Automotive comes highly recommended if it doesn’t work out I’ll give your guy a call you call these shops that advertise transmission repair but when you call them all they do is replace them lol I can do that thanks again
10-26-2021, 11:57 PM | #4 |
29 Palms (the stumps) Yikes
hope you get it sorted
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
10-28-2021, 12:06 PM | #5 |
Be nice now I grew up here I liked it better the way it was in the 50s and 60s. when I built my chassis eight years ago everybody was removing the three finger flange on the 6L 80 E transmission and using a 400 Bolton yolk with a slip joint in the driveshaft it hnas turned out to be a bad combination and it wears out the bushing in the extension housing,so I am having the output shaft and housing changed to one from A truck now I can use conventional driveshaft which I should’ve done in the first place. will be heading back to Florida in December
10-28-2021, 08:18 PM | #6 | |
Glad you are getting it fixed, and stay safe
10-29-2021, 07:13 PM | #7 |
Read your past posts and I'm following your lead in yoke/driveshaft design on my '66 C10 LS/6L80. Just about to cut metal on the Turbo 400 yoke. Please tell me more about your bad experience. Are you sure that was the cause of the bushing wear? How many miles did it last? I'm guessing that now I will have to swap in truck 2WD parts like you.
10-30-2021, 05:01 PM | #8 |
Thanks for the history. You just saved me a lot of time, money, and aggravation. Now off to find another 6L80 to get 2WD truck parts from.
10-30-2021, 06:21 PM | #9 |
The output shaft is the last thing that comes out and the first thing that goes back in you have to tear the whole thing apart to do it depending on how many miles on your transmission I would recommend a rebuild kit I’m not a transmission guy and my understanding is these have sum issues like cracks in the clutch housing and other stuff I don’t remember them all I started to do it myself but decided to let a pro that was familiar with the 6l80 do it I’m glad I was able to help
11-09-2021, 10:35 PM | #10 |
Here are the two parts that are needed... I think that is all. Hopefully this helps the next person with a '07-'11 6L80.
First is the output shaft assembly. It is GM p/n 24239394. That p/n has been supeseded and apparently the new p/n has been discontinued. That means a used part is the only option. I found a good used one from a person parting out a core. Second is the extension housing assembly. GM p/n 24224676 comes with the bushing and seal installed for ~ $75. It is all new and not made in China. I see many advertised for more than that for just a used casting that still needs a bushing and seal. |
11-09-2021, 11:11 PM | #11 |
Have mine back from the shop and installed works like it should had all the upgrades dun at the same time shifts much better are you going to do it your self or are you having it dun
11-11-2021, 06:09 PM | #12 |
The swap will have to be done by someone else
