Old 11-10-2021, 03:03 PM   #1
Willys_MB
Willys_MB's Avatar
Garage Sale - Big Variety - Some GMC Specific Parts
I have decided to sell off parts I’ve been hoarding for years now and just keep the ones I need. I need the space in my garage more than I need these parts!
Buyer pays shipping and fees. I will combine shipping costs if you buy more than one item. I have already taken pictures of most of this stuff, but a few things might have slipped through the cracks. It’s going to take a long time to upload pictures of all this stuff. I’ll work on shipping quotes the best that I can, but I also have a full-time job and a family to take care of, so please be patient. Follow board rules (respond in the thread). I’m open to reasonable offers on this stuff.
I’ll keep this initial post updated with sold and pending updates to prevent confusion.
Engine Bay Stuff
2. Aftermarket p/s bracket - Small Block Chevy Black Steel Power Steering Bracket Saginaw Pumps SBC 350 327 | eBay - $10 + shipping
3. 68 327 intake, oil fill tube carburetor, coil, and distributor (2 bbl), all were working when I pulled them off, I’ll include a new set of spark plug wires I purchased before I went to an HEI - $20 + shipping (shipping might be high with the cast iron intake)
5. Summit racing spread bore intake – I got it free from a friend, so you can have it for the cost of shipping
6. Carburetor adaptor, works both ways (spread to square bore or square to spread bore) - $10 + shipping
7. GM HEI Distributor, probably needs a rebuild - $40 + shipping
8. Small (6”) diameter harmonic damper – $5 + shipping
10. Original fan blade from my 68 327 setup - $10 + shipping
11. Manual steering box from my 1968 truck before I went to P/S. It needs a rebuild before being put back into service - $10 + shipping
12. Clam shell mounts – free if you pay shipping
13. Later model P/S pump with brackets. The pulley spins and looks like it works - $10 + shipping
14. Various pulleys – if you see one you want or need, call it out and make an offer
16. Spark plug wire brackets with new rubber wire holders painted chevy orange - $20 + shipping
18. Core support repair section bought from forum member atog - $35 + shipping
19. Power steering line clamp - $15 + shipping
Interior Stuff
23. Passenger side fresh air door, pulled from a 70 C10 in a local junkyard that hit a deer - $10 + shipping
26. 67-70 accelerator assembly. I pulled this out of my 1968 when I went to the throttle cable set up. Will come with the OEM pedal that still fits tight on the ball studs – $10 + shipping
27. Visors – Aqua/medium green, most have some tears or creases - $20 each + shipping or $50 for all of them + shipping
28. Visor clips, some aqua some light blue? Will probably clean up, but I’m not sure - $5 each + shipping or $20 for all of them + shipping
29. 67-68 parking brake cover - $35 + shipping
35. Passenger side vent window knob with washer and pin - $10 + shipping
36. Fuel gauge wire, no cracks, pretty good shape - $15 + shipping
37. Two rear view mirrors. Typical shape for original mirrors, look at pics closely - $15 each + shipping
38. Rear view mirror bracket. I think this is the later style bracket - $15 + shipping
39. Replacement lens for gauge cluster in great shape - $30 + shipping
40. Choke cable with standard knob, measures ~30” - $40 + shipping
42. Windshield wiper button escutcheon - $5 + shipping
43. Horn clock spring in great shape - $20 + shipping
44. Choke cable in original box measures ~72” no knob - $25 + shipping
49. 13/16” lug wrench - $20 + shipping
51. Tri Plus inner/outer rocker panel for driver side - $25 + shipping
51a. 67-68 Gauge cluster face - no cracks on any holes and in useable shape - $20 + shipping
Exterior Stuff
33. Tri-co wiper arms - $25 + shipping
54. 3/4-ton upper control arm rod. I painted one cap and lost it, so I ordered a second rod. Then when I was moving, I found the other cap. Only test fitted, never installed/torqued. - $10 + shipping
55. Spare tire carrier, has the threaded rod. $40 + shipping
56. Pair of original door handles pulled from a 1970 - $45 + shipping
57. GMC C2500 V-Eight fender emblems, studs intact and I’ll include four speed nuts for them - $45 + shipping
58. Driver door handle that needs a repair - $10 + shipping
59. Tail light lenses, no cracks - $30 + shipping
61. GMC park light housings (turn signal housings), driver quality, great shape, but one has a small crack (pictured) - $35 + shipping
Big Stuff - No Shipping
62. Primed front bumper never installed 67-70 and aftermarket - $150
63. Chrome front bumper, really clean 67-70 and OEM - $150
69. Tinted rear window with stainless trim - $100
SOLD STUFF
1. Spark plug wire brackets and heat shield from my 68 327 - $10 + shipping SOLD
4. Edelbrock 4 bbl carburetor 1407 (750 cfm). Was working when I pulled it off the motor and put it away in a box for a couple years - $100 + shipping SOLD
9. I think this is a 6 cyl. Fan guard? I got it in a box of parts - $10 + shipping SOLD
15. Throttle cable and bracket for a V8 setup - $25 + shipping SOLD
17. Engine lift brackets off a later model Chevy, easy way to pull a motor! - $20 + shipping SOLD
20. Hood hinges, they feel tight, but keep in mind they’re 50+ years old - $30 + shipping SOLD
21. Heater box with heater core in need of repair. The box has a small hole that someone covered with electrical tape. The blower still worked when I pulled it out - $15 + shipping SOLD
22. Turn signal lever, pretty clean, chrome in good condition - $15 + shipping SOLD
24. E-brake pedal, has the spring that’s always missing! – $25 + shipping SOLD
25. Pedal trim, has a small wear hole, but would be great for a driver - $5 + shipping SOLD
30. Door sill plates, I don’t see a part number so they may be aftermarket - $30 + shipping SOLD
31. Radio repair section - $40 + shipping SOLD
32. Radio delete plate with the ever evasive clips - $40 + shipping SOLD
34. Nice chrome GMC horn cap with good rubber and all parts shown - $50 + shipping SOLD
41. Window crank handles in great shape - $35 + shipping SOLD
45. True truck AM/FM radio with all brackets, harness, speaker. Untested, a good candidate for restoration (wow, I forgot how nice this was until I got it out to take pics). The FM tab is floating around and the AM tab is missing, but it might be inside the unit. - $450 + shipping SOLD
46. AM Radio with all brackets, harness, and speaker. Untested - $75 + shipping SOLD
47. 1968 Chevy glovebox door. Hinge functions and doesn't bind and the button is unlocked, but I don't have the key. $10 + shipping. Free for the cost of shipping if you have the truck it goes to. SOLD
48. Three-gauge cluster appears to be in good shape. There are no cracks around the screw holes and you can still see the outline of the choke delete, which I never had. The printed circuit has two little spots that I have photos of that might be problematic, but I don't know if continuity has been broken. $10 + shipping SOLD
50. Jack storage hardware (2 sets) - $25 each + shipping SOLD
52. R and L gravel shields, appear to be aftermarket - $20 + shipping SOLD
53. GMC headlight bezels. One ding on each bezel as shown in pics - $45 + shipping SOLD
60. Bulls eye reverse light lenses no cracks - $30 + shipping SOLD
64. Chrome front bumper with holes for lights - $150 SOLD
65. Passenger door - $250 SOLD
66. Aftermarket fleetside tailgate (no logo) - $175 SOLD
67. Stepside GMC tailgate - $100 + shipping SOLD
68. D/S fender well - $25 SOLD
Willys_MB is offline   Reply With Quote
Old 11-10-2021, 03:12 PM   #2
Willys_MB
Willys_MB's Avatar
Re: Garage Sale - Big Variety - Some GMC Specific Parts
Engine Bay Stuff
1968 GMC C2500 Long Bed Fleetside
Old 11-10-2021, 03:15 PM   #3
Willys_MB
Willys_MB's Avatar
2. Aftermarket p/s bracket (first pic)
3. 68 327 intake, oil fill tube carburetor (2 bbl), coil, and distributor, all were working when I pulled them off, I’ll include a new set of spark plug wires I purchased before I went to an HEI
Old 11-10-2021, 03:18 PM   #4
Willys_MB
Willys_MB's Avatar
3. 68 327 intake, oil fill tube, carburetor (2 bbl), coil, and distributor, all were working when I pulled them off, I’ll include a new set of spark plug wires I purchased before I went to an HEI - continued
Old 11-10-2021, 03:19 PM   #5
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:20 PM   #6
Willys_MB
Willys_MB's Avatar
4. Edelbrock 4 bbl carburetor 1407 (750 cfm). Was working when I pulled it off the motor and put it away in a box for a couple years - continued
Old 11-10-2021, 03:22 PM   #7
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:24 PM   #8
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:27 PM   #9
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:30 PM   #10
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:31 PM   #11
Willys_MB
Willys_MB's Avatar
14. Various pulleys – if you see one you want or need, call it out and make an offer - continued
Old 11-10-2021, 03:35 PM   #12
Willys_MB
Willys_MB's Avatar
18. Core support repair section bought from forum member atog - see his post here
Old 11-10-2021, 03:37 PM   #13
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:42 PM   #14
Willys_MB
Willys_MB's Avatar
Interior Stuff
Old 11-10-2021, 03:45 PM   #15
michael bustamante
michael bustamante's Avatar
pics of the gmc tailgate please, interested
can i see a pic of the gmc headlamp bezels as well? wanbt to see what year they are
1967custom
michael bustamante is offline   Reply With Quote
Old 11-10-2021, 03:49 PM   #16
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:51 PM   #17
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:54 PM   #18
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:56 PM   #19
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 03:58 PM   #20
Louisvillekytruck
Engine Bay Stuff
2. Aftermarket p/s bracket - Small Block Chevy Black Steel Power Steering Bracket Saginaw Pumps SBC 350 327 | eBay - $20 + shipping
3. 68 327 intake, oil fill tube carburetor, coil, and distributor (2 bbl), all were working when I pulled them off, I’ll include a new set of spark plug wires I purchased before I went to an HEI - $40 + shipping (shipping might be high with the cast iron intake)
4. Edelbrock 4 bbl carburetor 1407 (750 cfm). Was working when I pulled it off the motor and put it away in a box for a couple years - $125 + shipping
7. GM HEI Distributor, probably needs a rebuild - $50 + shipping
11. Manual steering box from my 1968 truck before I went to P/S. It needs a rebuild before being put back into service - $15 + shipping
13. Later model P/S pump with brackets. The pulley spins and looks like it works - $15 + shipping
16. Spark plug wire brackets with new rubber wire holders painted chevy orange - $25 + shipping
18. Core support repair section bought from forum member atog - $50 + shipping
21. Heater box with heater core in need of repair. The box has a small hole that someone covered with electrical tape. The blower still worked when I pulled it out - $20 + shipping
Interior Stuff
26. 67-70 accelerator assembly. I pulled this out of my 1968 when I went to the throttle cable set up. Will come with the OEM pedal that still fits tight on the ball studs – $15 + shipping
30. Door sill plates, I don’t see a part number so they may be aftermarket - $40 + shipping
32. Radio delete plate with the ever evasive clips - $45 + shipping
33. Tri-co wiper arms - $30 + shipping
39. Replacement lens for gauge cluster in great shape - $40 + shipping
40. Choke cable with standard knob, measures XX” - $40 + shipping
41. Window crank handles in great shape - $40 + shipping
42. Windshield washer button escutcheon - $5 + shipping
44. Choke cable in original box measures XX” no knob - $30 + shipping
45. True truck AM/FM radio with all brackets, harness, speaker. Untested, a good candidate for restoration - $450 + shipping
46. AM Radio with all brackets, harness, and speaker. Untested - $100 + shipping
47. 1968 Chevy glovebox door. Hinge functions and doesn't bind and the button is unlocked, but I don't have the key. $15 + shipping. Free for the cost of shipping if you have the truck it goes to.
51. Tri Plus inner/outer rocker panel for driver side - $30 + shipping
Exterior Stuff
53. GMC headlight bezels. One ding on each bezel as shown in pics - $50 + shipping
55. Spare tire carrier, has the threaded rod. $50 + shipping
56. Pair of original door handles pulled from a 1970 - $60 + shipping
57. GMC C2500 V-Eight fender emblems, studs intact and I’ll include four speed nuts for them - $50 + shipping
59. Tail light lenses, no cracks - $40 + shipping
61. GMC park light housings (turn signal housings), driver quality, great shape, but one has a small crack (pictured) - $40 + shipping
Big Stuff
62. Primed front bumper never installed - $100 + shipping
63. Chrome front bumper, really clean - $150 + shipping
64. Chrome front bumper with holes for lights, really clean except someone overtightened some bolts - $100 + shipping
65. Passenger door - $250 + shipping
66. Aftermarket fleetside tailgate (no logo) - $200 + shipping
Pics of chrome front bumper with holes how much to ship to Louisville ky and if its gm I want to have first dips
Louisvillekytruck is offline   Reply With Quote
Old 11-10-2021, 04:01 PM   #21
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 04:03 PM   #22
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 04:06 PM   #23
Willys_MB
Willys_MB's Avatar
Old 11-10-2021, 04:08 PM   #24
Willys_MB
Willys_MB's Avatar
43. Horn clock spring in great shape - continued
44. Choke cable in original box measures 72” no knob
Old 11-10-2021, 04:11 PM   #25
Willys_MB
Willys_MB's Avatar
51a. Gauge cluster face
[IMG]
[/IMG]
