11-12-2021, 12:55 AM | #1 |
Senior Moment
QA1 install on my Sons Truck. (Pics)
Doing the whole QA1 Coil Over setup on my Sons 71 GMC. Rear is done , more pics when we do the front
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
11-12-2021, 08:40 AM | #2 |
Re: QA1 install on my Sons Truck. (Pics)
Nice! Looking forward to seeing more pics.
11-12-2021, 09:00 AM | #3 |
Man, that's almost too sexy to cover up with a bed. Maybe put a plexiglass floor in the bed so you can still see it.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
11-12-2021, 11:07 AM | #4 |
Looks great-Hopefully you didn’t do what I did and hit the front truck arm heim joint bolts with an impact to get to the 140ftlb torque rating. Unbeknownst to me until I tried to take it back apart, but the bolts froze in the spacers as it appeared the spacers warped slightly. PITA to get it all apart but QA1 was awesome about replacing them.
Posted via Mobile Device |
11-12-2021, 01:48 PM | #5 | |
Senior Moment
Can’t wait to get started on the Front. I have the same set up on my truck with exception of the trailing arms (I already had solid ones). It’s the biggest and best up grade I’ve ever made. Unbelievable ride and lots of adjustments. He also went with the dual control shocks so he can adjust both compression and rebound Very nice product , Worth event penny. Everything front and rear ~$4500
11-12-2021, 01:02 PM | #6 |
Wow, looks impressive, thanks for sharing.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
11-12-2021, 03:03 PM | #7 |
Looks great. I am going to install the same on my step side. When do you plan on doing the front?
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
11-12-2021, 05:28 PM | #8 |
Senior Moment
I’ve done the front on my own truck if you have questions. Note. The upper ball joint does not ride like that. The pic was before any adjustments were made
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 11-13-2021 at 12:37 PM. |
11-12-2021, 05:52 PM | #9 |
That's awesome. What spring rates did you go with front and back.
11-13-2021, 12:21 AM | #10 |
Senior Moment
750 Front. 200 Rear. This is what QA recommend. Nice thing is , you can change springs pretty easily. I’m very happy with what I have now
11-13-2021, 06:52 PM | #11 |
Thanks so much. I will be ordering soon.
11-14-2021, 04:23 PM | #12 |
May be a bit of an odd question but what is the least amount of drop that you could use this kit at? Do you normally use dropped spindles with the kit? I am looking for a kit for my 72, but I want to run a big tire up front and not a lot of drop.
11-14-2021, 04:44 PM | #13 |
Senior Moment
Drop spindles are NOT required. My truck sets low but I can raise it ~ 3 inches with adjusting the springs. Will work on a totally stock set up as I read it
11-14-2021, 05:20 PM | #14 |
Thank you sir. I have been between this, Ridetech, or NoLimit. Best pricing through Summit or did you find it somewhere else?
11-15-2021, 12:17 AM | #15 | |
Senior Moment
Before my friend offered this deal I was looking at Summit and Speedway Motors for the best prices
11-15-2021, 02:43 PM | #16 |
Couple more quick questions:
Could the c notch be omitted if a new upper shock mount was fabricated? How do you plan to route the exhaust? |
11-27-2021, 08:47 AM | #17 | |
You like the setup on yours I take it? I'd like to pull the trigger while summit has it on sale!! lol Thanks, |
11-27-2021, 01:09 PM | #18 | |
Senior Moment
Also beware if your running 15” tires with tire height of 27” or less you’ll only have ~ 2 1/2 “ clearance from shock bracket to the Ground. That’s the only thing I didn’t like. I bought new wheels and tires that should be here in a week or two Going from 15/60s to 20/45 to gain some clearance. I have a set of Stock 73 spindles that will add back the 2 1/2 if I need them
11-27-2021, 03:51 PM | #19 | |
11-27-2021, 08:36 PM | #20 |
Senior Moment
Just installed them yesterday. They were easy to install and they look Cool but that’s all I can say right now as the Engine is still on the stand.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 11-27-2021 at 09:18 PM. |
11-27-2021, 11:06 AM | #21 |
Just an FYI but Summit has a rebate on these kits (at least the front kit) right now that are over $200 off their normal price , which you can add the Jegs code for an extra $100 off. Best price anywhere by far. And they are even in stock (I waited over 2 months for my rear kit when I bought it this past summer).
11-27-2021, 01:05 PM | #22 |
Great set up
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-27-2021, 05:17 PM | #23 |
I went with the QA1 front set-up on our 70 K5 because it would come close to stock ride height, supposed to be just one inch lower. It Will be a while before I drive it. We were recommended the 750 lb springs. We’re running a stock steel rim with 235/75R15 tires.
Not sure what were gonna do for the rear. I like the QA1, but I don’t want to lower the rear more than 1” to match the front.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
11-27-2021, 08:43 PM | #24 | |
Senior Moment
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 11-27-2021 at 09:22 PM. |
11-28-2021, 11:22 AM | #25 |
This thread has quite a bit of attention so I wanted to offer a warning for other QA1 owners.
I recently drove over some rough road (steep downhill with undulating surface) and I had a surprise when the lower control arm hit the road. Needless to say it upset the truck in the middle of a corner and it was violent enough for my passenger to comment. The damage is cosmetic, but did expose that the lowest point of the suspension is the shock itself. It took a chunk out of the eyelet and scraped the mounting bars/bracket. My takeaway is that you really need to run a taller tire than I have (27"), and be very aware of the road. If I had been driving more spiritedly, I could have lost control of the truck. |
