Old 11-14-2021, 08:08 PM   #1
Lugnutz65
Lugnutz65's Avatar
My 283 build.
I started with a zero mile 283ci That had been in storage. It was still on the shipping crate. The heads were mismatched, so I bought the correct head 520 casting head to match the other 520 powerpack head. The factory cam was changed out for a GK930 cam and then a double row timing chain. I had to find the rest of the parts including the correct Rochester 2jet carburetor, intake manifold, and accessory brackets. The chrome air cleaner will be replaced with an original 1966 factory correct 2 barrel air cleaner. I painted it gray. I like the color even though I realize it’s not the correct color gray.
It’s on the run stand for a break in run. VIDEO HERE.
Here are a few pics and ANOTHER VIDEO.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 11-14-2021, 08:47 PM   #2
MySons68C20
MySons68C20's Avatar
Re: My 283 build.
That is one gorgeous engine! I love the run stand and your set up.
I'm looking forward to the next video with some rpm
Thanks for sharing.
MySons68C20 is offline   Reply With Quote
Old 11-14-2021, 09:22 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Re: My 283 build.
Sweet! I love the color choice. Was that a grey from a rattle can?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 11-14-2021, 09:57 PM   #4
Lugnutz65
Lugnutz65's Avatar
Re: My 283 build.
Yes. I hope it holds up.
VHT primer. Then Dupli-Color Cast Coat Iron. I used Dupli-Color New Ford Gray for the script because I thought white would be too bright. Plus I had a whole spray can that was too light of a gray for the whole engine.
Old 11-14-2021, 10:27 PM   #5
Ziegelsteinfaust
Re: My 283 build.
I love that color. Originally I was going to paint my newer engine Black, but the iron grey is nice.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-14-2021, 10:52 PM   #6
AcampoDave
AcampoDave's Avatar
Re: My 283 build.
Man that's great, not too many 283's left around anymore. I'm glad you saved it. I really enjoy mine....A peppy little motor with decent MPG's. Should be a fun combo with a T5
AcampoDave is offline   Reply With Quote
Old 11-15-2021, 07:56 AM   #7
Lugnutz65
Lugnutz65's Avatar
Re: My 283 build.
I actually bought a fairly complete 1965 283 to scavenge parts for this engine. Pics below. Then a friend offered me a 1958 283 for parts. When I tore down the 1965 engine I noticed it had never been rebuilt. I couldn’t bear to see it go to scrap, so I sent it to the machine shop. Got it back 3 weeks ago. Now with 0.060 pistons, a Comp Cams 268H cam which will make it a moderate performance engine with a nice lope.
So, I actually have two freshly rebuilt 283s. I’ll assemble all the pieces, run stand test it and then decide which one I like best.
Old 07-17-2024, 02:06 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: My 283 build.
.060 over 283 = 292!
If it was one of the thicker casting blocks you can take them out to .125 and have a 301! One of the baddest little high winding engines ever!
Great builds you got going!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 11-14-2021, 11:15 PM   #9
cwcarpenter98
Re: My 283 build.
I like that color grey a lot better than the Ford grey. Thanks for the info!
Christian Carpenter
Old 11-15-2021, 08:11 PM   #10
AcampoDave
AcampoDave's Avatar
Re: My 283 build.
I hope you follow up here about how it performs when you get it going.
One of mine is nearly stock (except for an HEI and dual exhaust) still has the 3 on the tree and a 3.08 rear. The other has an Eddy 500 CFM carb with the EPS manifold, 305 HO heads, 4 speed Muncie, 3.08 rear and this cam...
Old 11-15-2021, 08:15 PM   #11
Lugnutz65
Lugnutz65's Avatar
Re: My 283 build.
I’ll certainly post a follow up.
So what comes next? Seriously! What do I do next?
I’ve heard the break in oil can’t be used for another engine break in. Yes, I have another one to break in.
Oil pressure was terrific. Temp stayed 195-200*. No major leaks. I did order a new water pump though.
So I’m thinking next steps are . . . .
Drain fluids
Look for oil in the coolant
Look for coolant in the oil
Inspect spark plugs
Bore scope the cylinders to look for issues.
Pull the rocker covers and inspect
Should I reset the valves?
Remember, be nice. This is my first new engine and I didn’t grow up around anyone mechanical.
Old 11-15-2021, 11:13 PM   #12
MikeB
MikeB's Avatar
Re: My 283 build.
That's really cool! I love 283s and 327s restored to almost original. Had a 283 4bbl in a 66 Nova Sport Coupe back in the day. That lightweight car was fairly quick for its time.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 11-29-2021, 09:23 PM   #13
RDrancher
RDrancher's Avatar
Re: My 283 build.
In for updates.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 11-29-2021, 10:05 PM   #14
67C10Step
67C10Step's Avatar
Re: My 283 build.
This thread makes me want to keep my little 283 for the long run. Not sure if it’s ever been rebuilt but it’s the factory engine. I’m building a cruiser and not an axle twisting tire smoker so the 283 might just keep its home.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 11-30-2021, 12:19 AM   #15
cwcarpenter98
Re: My 283 build.
That's the main reason why I decided to keep my truck 283 powered, even though I did an engine swap. That and a great deal on a running 283 sealed the deal for me.
It's funny to me that the majority of people who ask what engine is in it are surprised by it not being a 350
Christian Carpenter
Old 11-30-2021, 12:50 AM   #16
AcampoDave
AcampoDave's Avatar
Re: My 283 build.
I just took mine for a 3 hour drive in the hills last weekend and according to the miles of my route on Google Maps and the 9.6 gallons of gas I burned.....I got 15 mpg. I've spent a bit of time tuning my distributor and carb and I'm pretty happy with my 283 since gas in my area is creeping up on $4.50/gallon.
Old 11-30-2021, 09:31 AM   #17
Lugnutz65
Lugnutz65's Avatar
Re: My 283 build.
I pulled off the intake last night to fix a stripped bolt hole in the DS head. Here’s a link to the other thread. LINK
Old 12-01-2021, 12:55 AM   #18
SidsChopShop
Re: My 283 build.
Lugnutz the little 283 looks great! It sure has come a long way from when we saw it in your truck bed at the donut shop in Tennessee this summer!
SidsChopShop is offline   Reply With Quote
Old 12-01-2021, 06:20 PM   #19
Lugnutz65
Lugnutz65's Avatar
Re: My 283 build.
Yes, we did see each other. I must have showed you pictures because I had not started the assembly then just yet. I was playing with the carburetor rebuild at that point. Thanks for saying hi!
Soon I’ll have the intake back on and running on the stand after this short repair. Stay tuned.
Old 12-01-2021, 06:51 PM   #20
geezer#99
geezer#99's Avatar
Re: My 283 build.
I wonder how many heads got tossed on the scrap pile before helicoil’s were common? Or intakes or blocks for that matter.
Old 12-07-2021, 09:03 PM   #21
65truckowner
65truckowner's Avatar
Re: My 283 build.
I am glad to see someone else using a 283 Great little engine. I have a 66 c10 with the original 283 3 speed in it. I am planning on using it when I build the truck
65truckowner is offline   Reply With Quote
Old 12-12-2021, 12:21 PM   #22
Lugnutz65
Lugnutz65's Avatar
Re: My 283 build.
Update:
Fixed the bent pushrod issue. Everything checks out fine.
Made a video yesterday LINK right after adjusting the carb and dialing in the timing. Points distributor currently but will switch to Pertronix or possibly HEI.
Old 07-09-2024, 09:27 PM   #23
KVB
Re: My 283 build.
Following
KVB is offline   Reply With Quote
Old 07-09-2024, 09:54 PM   #24
Lugnutz65
Lugnutz65's Avatar
Re: My 283 build.
Originally Posted by KVB View Post
Following
This 283 is currently in my 1965 C10 short bed stepside and has about 2000 miles on it. First oil change looked good. Runs well and starts right up. This engine doesn't like my 0.72 overdrive gear. Runs great and likes the RPMs up around 2400. The HP curve on these engines drops off pretty fast with 2000 RPMs or lower. MPG is maybe 15 highway but I'm gonna try to get the timing dialed in a little better and it might improve.
Honestly though, my inline 230 six cylinder performs so well that it's hard to tell the difference and the 230 gets better MPG.
