Old 11-22-2021, 08:47 AM   #1
ozkiwi
GM crate 350 HO runs fine on regular 87?
The recommended fuel for my crate engine is 91 premium which is our 95 here in Australia but it runs fine on regular 87 with no pinging.
Does that motor really require premium?
ozkiwi is offline   Reply With Quote
Old 11-22-2021, 09:29 AM   #2
S10Fan
Old Heap Driver
Re: GM crate 350 HO runs fine on regular 87?
A TV show on the Motor Trend network here in the states, "Engine Masters" did a fuel test using different octane levels. The test basically showed little to no difference between grades of gasoline. If you're not racing and not pinging, go for it was their conclusion.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-22-2021, 06:47 PM   #3
ozkiwi
Thanks I think my experience confirms that but nice to know someone has done it in a controlled way.
Old 11-22-2021, 11:43 AM   #4
hatzie
Moderator
hatzie's Avatar
If it's not pinging run it.
Pay attention in the hot months when you're running it under heavy load like uphill towing at lower RPMs. It may ping under those conditions and not at all otherwise.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-23-2021, 07:46 AM   #5
Nick_R_23
Nick_R_23's Avatar
If it’s only recommended, then no, it’s not completely required, but you may run into high load situations like hill climbing, towing, hauling heavy loads, etc that may push you into detonation territory. Running conservative timing will help suppress that, but you also may not be getting full potential from your engine.
In a previous industry I was in, it was advertised as 87 min/91 rec. This means you could run as low as 87, but the ECM would pull timing using fuel rated below 91. 87 was just the max it would compensate to.
Old 11-23-2021, 06:58 PM   #6
ozkiwi
No pinging even in hot weather underload on regular. The mechanic who installed the motor said he set the timing conservatively which I assume is slightly retarded. It starts instantly and makes more than enough power for my use.
It replaced a tired 305 so I guess thats why it has more than met my expectations.
