Old 11-23-2021, 07:55 AM   #1
C3pilot
292 Motor mount
Thinking about doing a 292 in my ‘72 C10.
C3pilot is offline   Reply With Quote
Old 11-23-2021, 11:24 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 292 Motor mount
You need to be a Premium member to post a WTB. If you see anything for sale on the parts board you can buy it, you just can't post the WTB.
http://67-72chevytrucks.com/vboard/payments.php
Thanks,
LockDoc, Moderator
Leon
Old 11-23-2021, 01:09 PM   #3
kwmech
Re: 292 Motor mount
If I was able to locate all the parts I'd be inclined to do the same. Never had an inline in any of the trucks I've rebuilt.
kwmech is online now   Reply With Quote
Old 11-23-2021, 03:16 PM   #4
C3pilot
Re: 292 Motor mount
Thanks,
LockDoc, Moderator
My bad LocDoc, I’ll look into it.
C3pilot
Old 11-23-2021, 04:28 PM   #5
LockDoc
LockDoc's Avatar
Re: 292 Motor mount
C3pilot
Without looking I think the 6 month subscription is 15 bucks. Then you could post a WTB on the parts board.
LockDoc
Leon
Old 11-28-2021, 08:21 AM   #6
C3pilot
Re: 292 Motor mount
Thanks,
LockDoc, Moderator
LockDoc, followed your suggestion and upgraded my membership. Posted a WTB this morning in the parts forum so hopefully I’ll be able find a 292 frame perch and motor mount. C3pilot
Old 11-28-2021, 11:25 AM   #7
LockDoc
LockDoc's Avatar
Re: 292 Motor mount
Good deal! Thanks. That will be your best bet for finding something.
LockDoc
Leon
Old 11-23-2021, 07:41 PM   #8
BigBird05
Re: 292 Motor mount
There are a lot of people pulling l-6 engines. It should be easy for you to fine everything you need.
BigBird05 is offline   Reply With Quote
Old 11-23-2021, 08:27 PM   #9
Grumpy old man
Grumpy old man's Avatar
Re: 292 Motor mount
The 250 /6 parts are easy , The 292 Passenger side engine perch not so easy .
No, Sorry there not for sale .
Old 11-24-2021, 01:15 AM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 292 Motor mount
Then there's the 292-only 4x4 diagonal engine crossmember.
Forged from refined Inobtainium.
However, unnecessary in a C/10 installation.
Old 11-24-2021, 02:49 AM   #11
kwmech
Re: 292 Motor mount
Was the inobtainium brought in from Pandora?
Old 11-24-2021, 05:07 AM   #12
'68OrangeSunshine
Re: 292 Motor mount
I'll have to look inside the box to be sure...
Old 11-26-2021, 08:11 PM   #13
May70
May70's Avatar
Re: 292 Motor mount
How come the passenger side perches are harder to find? Just curious
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 11-26-2021, 08:43 PM   #14
Grumpy old man
Re: 292 Motor mount
I'm thinking there were less produced ,But so many 6 cylinders were swapped over to small blocks and you can just drop a small block in place of the 250 using the same 250 engine perches .You can't use the right side 292 perch with a small block so they probably got tossed off to the side and replaced with a 250 right side perch or a set of small block perches ? anybodies guess ? there are probably a bunch laying under garage work benches all over the country . Last I noticed they were selling for about $100.00 for the right side .
Old 11-27-2021, 06:17 AM   #15
'68OrangeSunshine
Re: 292 Motor mount
Be nice if somebody could stamp some more out, instead of a goofy way to foul up the Mechanical Fuel Pump.
Old 11-27-2021, 08:28 AM   #16
BigBird05
Re: 292 Motor mount
I've got a question about this. If it is not a nut an bolt restoration could you move up to the 73 frame and engine mounts?
Old 11-27-2021, 03:46 PM   #17
'68OrangeSunshine
Re: 292 Motor mount
You could, I guess. You could move all the 67/72 body parts over too. But the 292 would still need its own RH Mount.
Old 11-27-2021, 05:13 PM   #18
C3pilot
Re: 292 Motor mount
How similar are the frames?
Old 11-27-2021, 10:26 PM   #19
LockDoc
LockDoc's Avatar
Re: 292 Motor mount
You can use the '73 frame brackets on the SB and BB engines with a little modification but I think it would take quite a bit of modification to use them on the 292 engines, at least on the right side.
LockDoc
Leon
Old 11-28-2021, 10:08 AM   #20
BigBird05
Re: 292 Motor mount
Sorry, I didn't proof read my question. I meant to use the frame brackets.
