![]() ![]() Join Date: Dec 1999
49 rear gastank options?
I remember reading that you can put a rear mounted gas tank out of a 69 Camaro into the 47-52 truck frame in the rear?
Anyone done it?
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
![]() Join Date: Jul 2007
Re: 49 rear gastank options?
A Camaro tank is right at 39.375 wide. That according to these measurements
Fuel Tank Length (in.): 39.375 in. Fuel Tank Width (in.): 20.875 in. Fuel Tank Height (in.): 7.750 in. https://www.summitracing.com/parts/t.../1969#overview As many times as I have measured the frames I don't remember the inside measurements off the top of my head. I can't actually read them off the image I saved off the assembly manual either. ![]()
Here is the Gen 1 Camaro tank installed in my '51 half-ton frame:
1951 Chevy Panel Truck Last edited by MiraclePieCo; 11-29-2021 at 02:26 AM. |
Thank you so much!
I have done it too. I cut the filler neck and had it come up in the bed floor. You can get fuel hose from Summit Racing at the angle you need. This is what I used.
https://www.summitracing.com/parts/TNK-NE-60 Tanks Inc. Fuel Tank Filler Neck Hoses. TNK-NE-60 https://www.summitracing.com/parts/TNK-FN-FMC Tanks Inc. Fuel Filler Neck and Cap Kits TNK-FN-FMC |
![]() Join Date: Mar 2007
I used a Camaro tank in my 1/2 ton Suburban. I also modified the filler neck to come up straight thru the rear floor. Worked great. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#7 | |
1951 Chevy Panel Truck |
Thanks for all your help. Quick responses helped me snag a brand new Camaro tank on FB marketplace. New sending unit installed already. Tank straps too.
$95 and super local.
gas tank
any one done a rear fill with camaro gas tank with pictures 1949 chevy truck 3100
Here's a gen 2 Camaro tank in a '49 GMC - I run a roll pan and no bumper with the filler neck under the license plate. There's a 4"x4" .25" wall square tube at the end of the rear frame rail to protect the tank
![]() The tank is for the Camaro with a big block, which has a vent/return that I used for my fuel injection return Here's the tank installed before the bed wood went in. There's enough room on either side to run the exhaust if you want to go out the back ![]() Here's a shot of the tank from the underside of the truck with the bed-wood installed ![]() Here's a shot of the rear of the truck so you can see how the tank tucks up to be flush with the roll pan - you can see a little bit of the tank, but this photo is taken at the level of the license plate. You can also see about 1/4" of the 4x4" crossmember. Neither one is visible with the truck on the ground ![]() |
Correction - I think there's only one Gen 2 tank for the Camaro - the extra vent comes with the fuel sender for the big block
How well does that filler neck being that low work with filling the tank though? It looks like you have modified the neck to get the filler lower and that may cause some real issues filling the tank.
#13 | |
Marc
The filler neck on my tank is unmodified - there's never been a problem filling the tank.
The problem is that I'm 67 years old now, and the truck is fairly low. I used to be able to squat/bend down pretty easily, but now it is just easier to go down on one knee to fill it |
#15 | |
#16 |
I have seen a few modified to accept a filler on the rear fender. some nicely done, some farm/work truck look, some race car look with the bolt on flange around the outside, some that look like the stock cab filler except on the rear fender to look period correct. some have a door, some don't. the door ones are harder to get looking and fitting nice on an egg shaped surface. personal preference. personally I wouldn't put the filler in the box floor because I haul stuff. of course I would need to fill when there is something in the box, lol. also, the box floor sometimes means the filler hose needs to drag across the paint.
I remember as a kid at the filling station we had a guy with a 67-72 era chevy pick up and he had a rear tank with the filler behind the lic plate. when we seen it coming we would always try to get the other guy to run out and fill it up because it almost always burped back and got gas on the ground or your shoes. maybe some of the newer tanks have the anti siphon/roll over protection valve installed at the tank entrance of the tank? sometimes they are built into the tank filler hose and sometimes they are built right into the fill connection of the tank. |
#17 |
I have seen a truck on here somewhere that utilised the bed stake pocket for a gas filler. the filler is up high so no chance of leaking or blowing back. it may fill slow though since the piping couldn't be very large.
has anybody used an S10 blazer tank? they have a side filler. just curious. |
#18 |
for the life of me i dont understand the fascination with putting the filler in the bed floor. a friend had that setup in a 46 Chevy truck and everything in the box stunk of gas fumes each time it was filled. i would do everything in my power not to do that.
Also a 67-70 mustang tank will also slide right into the frame rails. Just an opinion, thats all. |
#19 | |
Marc
#20 |
youngrodder, your filler is capped under the floor with an access door to the filler, correct? like a fuel fill door on the side of the vehicle on newer cars? that way the cap could vent or overflow a bit when filling but the fumes/gas would escape outside the cab? some bed floor fillers I have seen are like that and some are a filler tube coming through the floor with a simple cap at the bed floor level. some guys use a marine fuel tank filler as they are usually chromed or are finished nicely. they usually have a little chain or something inside the filler tube to keep the cap from getting lost as well. some also have the extra tube for the fill vent. some are flat with a special key to open, some are locking, some have a flip up lever to twist it open. they would look equally nice on a fender mount, an under floor mount or in the bed floor if thats what you are after. some marine places also sell the aesthetically pleasing access doors as well.
#21 | |
Maybe your friend was sloppy with the gas nozzle.
