Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 11-29-2021, 05:58 PM   #1
HO455
HO455's Avatar
Wood floor replacment bolts and metal strips.
AWhen I replaced the wood floor in my Suburban I found that the 5 smooth top countersunk bolts (1/4-20 Plow Head bolts) that are across the rear of floor are not available.
These fasteners are usually rusted and have a tendency to twist in two when removing. I ended up modifying the closest bolts I could locate on my lathe to make replacement bolts. (Quick word of thanks to Richard 2717) These are a close but not perfect replica of the originals. The biggest difference being the countersunk area on the back of the bolt is smaller. The downside of this may be a reduction in how much torque the bolt will take before the head would deform. I had no problems with this when I installed them in my floor. The bolts have been sprayed with cold galvanizing paint. I have 10 sets.
I also have 2 of the metal strips that go across the rear that I had made. Mine was too rusted to reuse. These pieces are not drilled and countersunk at l present but I will do that before shipping. The reason I haven't done it yet is that when I did mine I noticed the holes were not consistent in their spacing. I would need to know the specific spacing measurements from your Suburban or that you would be okay with having to drill additional holes in your truck to get the bolts installed.
Here is a link to the floor replacement part of my repair thread. It goes on for several pages with a couple of detours before completion.
https://67-72chevytrucks.com/vboard/...698377&page=20
Pricing for the bolts is $25.00 for a set of 5 shipped. (As of 10/23)
Pricing for a rear strip is $45 plus the shipping.
I also have one factory front hold down strip with extra holes drilled in it for $25 plus shipping.
There are no more of the #1 bolts (See post #9) available at present. (12/23)
More information on the bolts.
http://67-72chevytrucks.com/vboard/s...d.php?t=721207
RIP Bob Parks.
Old 11-29-2021, 06:03 PM   #2
HO455
HO455's Avatar
Re: Wood floor replacment bolts and metal strips.
Photos of the finished strip I used in my Burban.
RIP Bob Parks.
Old 11-30-2021, 02:35 PM   #3
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Those turned out nice
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 11-30-2021, 11:55 PM   #4
HO455
HO455's Avatar
Thank you Richard, for everything.
RIP Bob Parks.
Old 01-19-2022, 05:53 PM   #5
HO455
HO455's Avatar
Additional photos of the countsink or dimple process. 1st one is the die I made to do the job. 2nd one is test fitting in the factory piece. 3rd is the testing program.
RIP Bob Parks.
Old 01-22-2022, 08:48 PM   #6
Getter-Done
Getter-Done's Avatar
I like your punch and die setup
84 Chevy K-20
Old 01-25-2022, 07:18 PM   #7
HO455
HO455's Avatar
Thank you. It was an enjoyable little lathe project.
RIP Bob Parks.
Old 04-10-2022, 11:01 AM   #8
HO455
HO455's Avatar
Bump to the top.
RIP Bob Parks.
Old 08-08-2022, 02:32 PM   #9
HO455
HO455's Avatar
I now have 4 sets of 12 of the # 1 bolt in the first photo below. They are not an exact match to the ones the factory used (Photo 3). The factory ones had 7/8" head with a 1" long 3/8 shaft.
These have a 1" head with a 1- 1/2" 5/16" shaft. (Photo 2). They do however have the same shallow dome head as the factory bolts did. Visually They would be amost indistinguishable from a factory bolt once installed.
Modern carriage head bolts have a much smaller head with a rounder dome head or the other option would be a head with a slot and no square shank under the head. Photos 4 & 5.
I will include 12 of these for no charge with an order of the rear bolt set.
RIP Bob Parks.
Old 08-14-2022, 12:22 PM   #10
knuckle-nurse
I will take a set. Thanks.
knuckle-nurse is offline   Reply With Quote
Old 08-15-2022, 12:35 PM   #11
HO455
HO455's Avatar
PM sent
RIP Bob Parks.
Old 08-24-2022, 05:39 PM   #12
HO455
HO455's Avatar
Payment received and package posted. Tracking number sent via PM.
Thank you and good luck on your project.
RIP Bob Parks.
Old 10-05-2022, 12:52 PM   #13
adzints7
Junior Member
I sent a Pm. Thanks!
adzints7 is offline   Reply With Quote
Old 10-05-2022, 01:00 PM   #14
HO455
HO455's Avatar
Reply sent,
RIP Bob Parks.
Old 11-30-2022, 02:34 PM   #15
67chevy2wd
67chevy2wd's Avatar
Received the parts. Thanks again.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 03-11-2023, 11:45 AM   #16
HO455
HO455's Avatar
Bumping to the top. Parts still available.
RIP Bob Parks.
Old 07-19-2023, 11:30 PM   #17
HO455
HO455's Avatar
Bump for summer project.
RIP Bob Parks.
Old 10-06-2023, 09:19 AM   #18
HO455
HO455's Avatar
Bump up for winter project.
RIP Bob Parks.
Old 10-10-2023, 06:50 AM   #19
nsiti
Hi, I'll take one set of each of the two types of bolts, thanks. Will PM you.
nsiti is offline   Reply With Quote
Old 10-10-2023, 09:11 AM   #20
HO455
HO455's Avatar
PM sent.
RIP Bob Parks.
Old 10-24-2023, 10:05 PM   #21
HO455
HO455's Avatar
Payment arrived. PM sent.
RIP Bob Parks.
Old 10-26-2023, 03:25 PM   #22
HO455
HO455's Avatar
Bolts shipped.
Just an update to the original ad I posted. Due to the increased cost of shipping a bolt set is now $25 dollars.
And I only have one set of the additional free bolts left. Order soon!
RIP Bob Parks.
Old 12-17-2023, 10:17 AM   #23
dadsburb
Hi I would like to purchase a bolt set.
dadsburb is offline   Reply With Quote
