Old 12-17-2021, 10:56 AM   #1
1970 CST
1970 CST's Avatar
What would you do?
Looking for some opinions here. I currently have a 1970 CST with a 3 OTT that had an engine swap by the PO. It is supposed to be a 327 but the ID on the block indicates it is a 307. In the beginning I thought the 3 OTT was pretty cool but now not so much. While looking for some tractor parts on an old farm I came across this 1970 that is in rough shape but appears to have the original 350 with an Auto trans and A/C (my current truck has A/C). I can pick up the truck for around $1,000 or less. I will at least be able to verify that the motor isns't seized but I would have no way to verify the engine is sound before buying it. So the question is what should I do? What would you do?
Terry
1970 CST is offline   Reply With Quote
Old 12-17-2021, 11:03 AM   #2
Louisvillekytruck
Re: What would you do?
Does it have a title
Louisvillekytruck is online now   Reply With Quote
Old 12-17-2021, 11:08 AM   #3
1970 CST
1970 CST's Avatar
Yes it would have a title.
Old 12-17-2021, 11:19 AM   #4
Louisvillekytruck
The title helps. u can turn the motor over by hand
Old 12-17-2021, 11:10 AM   #5
Mickeymotormount
Active Member
Mickeymotormount's Avatar
Tell the seller you are interested only if you hear the engine run. Bring a battery, some fresh gas, hoses, some wire to hot wire it and start it up.
John
1967 C20 2WD Longbed
2001 2500 HD 4X4 Extended cab long bed
Mickeymotormount is offline   Reply With Quote
Old 12-17-2021, 11:47 AM   #6
67C10Step
67C10Step's Avatar
With title and if the engine isn't locked up I'd say it's a good buy. If you could spend a bit of time like Mickey said and at least get it to sputter a bit, even better.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 12-17-2021, 06:35 PM   #7
Find a Saginaw car 4spd. It will slip right into the place of the 3spd. or are you wanting to drive with one foot?
Old 12-17-2021, 09:43 PM   #8
palallin
Are you sure the '70 shoudl have a 327? I would think a 307 is far more likely.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 12-17-2021, 09:54 PM   #9
1970 CST
1970 CST's Avatar
The PO installed a "327" that is not a real 327. The numbers on the block indicate it is a 307. According to the SPID my truck came with a 350. My thoughts were that the donor truck I found could be a perfect way to get an original 1970 350 for my truck. And while I'm at it I could upgrade to an automatic trans as well.
Old 12-17-2021, 09:50 PM   #10
truckster
truckster's Avatar
A 70 with all the parts and a title is worth $1000 easily, even if it doesn't run. You can buy it, check it out, and if you decide not to use it, clean it up a bit and sell it for a profit.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-18-2021, 01:53 AM   #11
Accelo
Accelo's Avatar
If a stock truck is what you want it would be difficult to gather all the parts without paying more. You should be able to recoup much of your investment on the other truck parts.
Confirm the numbers on the replacement block before purchasing.
Down side would be if the block is cracked. I would check for antifreeze. I had a block crack, in my shop. It had only water in it. Didn't even have a water pump on it.
The transmission conversion parts are also expensive. You will get the transmission, linkage, driveline, cross-member and steering column. Nice haul in my book.
Interesting someone liked the 72 door panels enough to retrofit them. Too bad the seats are not originals!
Accelo is online now   Reply With Quote
Old 12-18-2021, 02:25 AM   #12
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
I’d drag that home. $1000 bucks or less, otherwise complete truck with a title. That’s a score (around here definitely) regardless of running/driving these days. Provided you have the room for it of course.
Canadian694x4 is offline   Reply With Quote
Old 12-18-2021, 08:20 AM   #13
Did you read his first post??
Old 12-18-2021, 11:42 AM   #14
palallin
Nope, I missed that phrase. Apologies to the OP and, apparently, you. . . .
Old 12-18-2021, 10:31 AM   #15
Redneck Rydes
Redneck Rydes's Avatar
For a $1000 I would buy it for all the parts plus ownership!!
Redneck Rydes is offline   Reply With Quote
Old 12-18-2021, 11:00 AM   #16
Warrens69GMC
Warrens69GMC's Avatar
I would have it home the same day.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-18-2021, 08:01 PM   #17
No need to apologize to me since I have no reason to be offended. I didn't mean to offend you then, nor do I now when I say I don't always read through the entire thread but I at least read the first post before questioning or correcting the OP.
Old 12-18-2021, 08:52 PM   #18
truckster
truckster's Avatar
I'm just waiting for him to come back on here and tell us he's dragged it home...
Old 12-18-2021, 10:04 PM   #19
BigBird05
There's enough parts there for me to drive up to NY and bring it home for $1000.
BigBird05 is offline   Reply With Quote
Old 12-19-2021, 12:09 PM   #20
Mickeymotormount
Active Member
Agreed. Nice find either way.
John
Old 12-19-2021, 03:55 PM   #21
1970 CST
1970 CST's Avatar
Big Bird, No need for you to drive up to NY, I'd rather keep it for myself.
Old 12-23-2021, 04:54 PM   #22
1970 CST
1970 CST's Avatar
Very disappointed today. I went to look over the truck and found out that the engine, according to the numbers, was out of a 1974 camaro or nova. I was really hoping for an original 1970 Chevy P/U motor. Oh well. Also there wasn't one good panel on the truck and the interior wasn't much better. Hardly anything that could be sold for parts. Still trying to decide if it is worth buying it for the motor, trans and steering column. My truck doesn't have an original motor now so it really doesn't matter if it's out of a 1974. And I think it would be nice to have an auto trans instead of the 3 OTT.
Old 12-23-2021, 06:23 PM   #23
BigBird05
If you do end up buying it and are selling parts I will send you my list.
Old 12-23-2021, 06:48 PM   #24
1970 CST
1970 CST's Avatar
If you let me know what you are looking for I could let you know if any of what you need is there or in decent shape.
Old 12-29-2021, 04:59 PM   #25
1970 CST
1970 CST's Avatar
Final update on the donor truck. Talked to the yard owner today and he was unwilling to budge on the price. Told me that he could get $800 for scrap? Seemed pretty high for scrap but it's his truck. Oh well, they say have the fun is looking for parts.
