Old 12-18-2021, 05:12 AM   #1
Redneck Rydes
Redneck Rydes's Avatar
Under dash clunk
I picked up a 2002 RCSB that I did a bit of work to,put a 2/4 kit in it,and some basic maintenance,but it had the dreaded under dash clunk,as you probally well know it is the lower steering column bushing,very common on these truck,it is very annoying,well after doing some research on the web,I stumbled across a guy who put a rad hose clamp around the lower pert of the column and the bushing,well I tried it,and it worked,no more clunk,also while I was the down there,it also had famous brake pedal wobble also,went to GM and for 89 cents picked up a brake pedal bushing,changed that out,and absolutely no more rattles from under the dash while driving on rough roads.Just thought I would let everyone know about this trick if you have been trying to chase thes rattles down.
Redneck Rydes is offline   Reply With Quote
Old 12-19-2021, 07:00 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Under dash clunk
Nice job. I just changed out my bearing. I disassembled the new one and added grease around the bearings. Should help it last.
Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
