Old 12-19-2021, 04:00 PM   #1
Ziegelsteinfaust
73+ C10 drop spindles
I am looking at these as I think they help pull the wheels in a bit. Plus offer easy brake upgrades if I ever feel I need them.
http://www.cpptalk.com/ShopTalkSite/st52.html
I liked the Willwoods, but I am concerned of the aluminum construction. As I plan to abuse the truck, and use C20 lower ball joints. Plus brake kits are expensive. Plus the CPP version uses cheap factory replacement items as this is my daily.
If I could use a K10 rotor, and factory D52 caliper it would be a better choice for me.
Ziegelsteinfaust is offline   Reply With Quote
Old 12-20-2021, 03:14 PM   #2
SCOTI
SCOTI's Avatar
Re: 73+ C10 drop spindles
Those spindles plus the correct caliper bracket allows you to start w/the OE size 12" rotor/D52 combo & upgrade to current big-brakes w/multi-piston calipers in the future if desired (and you have the coin for the modern diameter wheels/tires required for them).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-20-2021, 04:14 PM   #3
Ziegelsteinfaust
Do they pull in the wheels? They seem to elude to that fact, or is it not that big a deal?
Old 12-20-2021, 05:00 PM   #4
SCOTI
SCOTI's Avatar
The CPP 'Modular' spindle's are supposed to not increase track width like typical drop spindles. I didn't measure mine to definitively prove or disprove if they did when I swapped them under my 64's chassis. Maybe I'll pull one off for a tape measure comparison.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-20-2021, 07:16 PM   #5
Ziegelsteinfaust
I hope they don't increase track width. My 17x9's just fit with a 1/4 to spare.
