![]() Join Date: Nov 2013
My Carb & Manifold setup
Thought I purchased a 71 But its turn out to be a 72 According to DMV & the vin # But its still a sb Step side. Q jet for a carb & cast iron manifold. Question IS ??
Q Jet, Holley OR Edelbrock Carb And what about the Manifold ? Q jet works but not the choke. Looking for input. Will change to HEI SOON. |
![]() Join Date: Feb 2016
Re: My Carb & Manifold setup
Why open the Pandora's Box of carburetor swapping if you have a good Qjet? I would get an electric choke conversion and be done with it. I've done it on several daily drivers without isues.
https://www.carburetor-parts.com/rochesterecc.html Link to how I did mine. Scroll to post 590. https://67-72chevytrucks.com/vboard/...698377&page=24
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Jan 2001
Probably the best and easiest solution is to rebuild your Q-Jet. You won't need any adapters or customization or anything. As far as the manifold, if you're running a stock engine, there's no reason to replace it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
If it runs good, keep running it.
If it doesn’t run good, rebuild it.�� The Q-jet is a great everyday carb |
![]() Join Date: Jun 2005
If it ain’t broke, don’t fix it. Is there an issue with the carb or manifold, or do you just want to change them?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
I like Holley’s on a high performance application, but I prefer Q-jets on milder drivers. And if it sits a lot and doesn’t get run out to higher rpm, the single float bowl of the Q-jet is preferential. I like that you can run oem steel lines on either application that you can’t with the Edelbrock (although The Right Stuff makes an Edelbrock steel line for SBC applications).
In a nutshell, I am in the keep the Q-jet and sort it out camp. Converting to electric choke a great idea.
