Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-11-2022, 11:25 PM   #1
JJH Jimmy
JJH Jimmy's Avatar
WTB Scottsdale Door Panel Inserts
WTB 81-87 Scottsdale door panel inserts like these. Thanks for the picture Keith!
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 01-16-2022, 10:04 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: WTB Scottsdale Door Panel Inserts
if you talking about upper inserts wo/chrome If there still made the same any of the chromed one you just peel off the stick on chrome and you have the Reg black option ones. On factory ones, and If some one have one that LMC that broken badly scratched just peel off and we should find out. If you have a new set use a little heat take your time do not bend you can re use them on others sell.
I hope this helps you and other.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-17-2022, 10:22 AM   #3
JJH Jimmy
JJH Jimmy's Avatar
Interesting. I have a set of old repop chrome ones and i will give it a try. Thanks for the tip!
1985 Chevy K20
1994 GMC Yukon
