Old 12-29-2003, 01:56 AM   #1
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Tall valve covers on a SBC
Whats the usual solution to having tall valve covers and a drivers side, short water pump alternator? I have to take off the valve cover to remove the alt belt.
Cat Fuzz is offline   Reply With Quote
Old 12-29-2003, 02:33 AM   #2
dinnut
dinnut's Avatar
you have a/c? why would you have to take the valve cover off? alt is usually on pass. side... unless you have a/c... unless short water pumps are a lot different
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-29-2003, 05:02 AM   #3
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
I dont have tall valve covers or A/C, but its not really close with my Alternator on the drivers side and short pump. Then again, my 350 is out of a 74'...
What is hitting and where? what bracket are you using? Any pics?
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 12-29-2003, 08:41 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Dinnut, short pumps ARE a lot different. These thrucks came stock with short pumps you know! Alternator was on the driver's side stock.
Cat Fuzz, I've had that problem. The solution I found was to run a Corvette upper alternator bracket. It's longer and swings the alternator out wider away from the engine. I'm talking about the curved arm with the slot in it. I can get you the GM number if you need it. They are still available at the dealer and under 10 bucks last one I bought.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-29-2003, 08:42 AM   #5
Tx Firefighter
Number for longer Corvette bracket is GM # 460754
Old 12-29-2003, 01:57 PM   #6
Chevelle454
Chevelle454's Avatar
I have also recently discovered this problem when I installed new valve covers. Couldn't you also just get a slightly longer belt?
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 12-29-2003, 02:07 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Thank's for the part # tex as I am getting tire of taking the alt bracket off to adjust the valve's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-29-2003, 02:40 PM   #8
special70gmc
special70gmc's Avatar
i too have to take my valve covers off and i dont evan have really tall covers. it kinda sucks. -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-29-2003, 03:55 PM   #9
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Heres a pic. The problem is when I go to take off the belt, it won't swing back far enough to be able to get the belt off. A longer belt only maxed out the adjustment. I made an extension bracket for a temporary fix, but it looks uber cheesy.
Thanks for the part number Tx! You say its only about 10 bucks? Sweet.
Old 12-29-2003, 05:50 PM   #10
Tx Firefighter
The vette lower bracket also interchanges onto our trucks. It's aluminum rather than cast iron. Also, it spaces the alternator directly outward from where it is now. It moves it exactly towards the fender. Between the two, the alternator is moved a good bit to the drivers side from where it is now.
Old 12-29-2003, 06:19 PM   #11
dinnut
dinnut's Avatar
wow. thanks tx firefighter. the engines in both of my trucks are not stock and didnt know these trucks came with short water pumps and with the alt. on the drivers side. both of mine are tall water pumps i guess...
70 longbed
496/th400/Ford 9"
Old 12-29-2003, 06:27 PM   #12
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Originally posted by Cat Fuzz
uber cheesy.
Sorry dude it struck me funny.
Tx's info sounds the best for your situation. *wishin I had bolt holes in my head* um.. wait...
I wanted to add a note. The Alan Grove Driver-Side-Short-Waterpump Alternator bracket mounts the Alt far enough toward the fender as not to get in the way of the tall valve covers. This is an expensive fix, but if you didn't have bolt holes in the head it would be a good solid fix. IM 'humble' O
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
