![]() Join Date: Feb 2004
1951 Crosley Sport -- how?
The rear axles on a Crosley are a tapered key shaft with a castle nut and cotter key. The rear drum is also the hub that is female taper.
Do I treat this like a wheel bearing?? Tighten it to snug, maybe backoff for a slot to put the cotter key thru. Or do you always go tighter to get the cotter key thru? These cast iron tapered drum/hubs are precious. You do not want to crack one. The key is put in after the hub is placed on the tapered axle pushed in just far enough to start the castle nut which finishes pushing the key in to tight.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 01-14-2022 at 08:11 PM. Reason: words |
![]() Join Date: Dec 2009
Re: 1951 Crosley Sport -- how?
Pictures would help.
Is yours set up with one tapered bearing on each axle? I will tell what I learn about taper axle shafts. My 1952 8N Ford rear axle are tapered splines if it pertains to your situation.
The diff is for a 39 Crosley but is similar except the drum/hubs on a 51 have no slots. Crosleys are 1939 to 1952 made by the washing machine refrigerator company in Cincinnati.
The axle is from a 48 jeep but is the same. There are no splines, just one square key. I think the axle bearing has no role in putting drum/hub on this tapered axle. This car has only 25hp.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 01-15-2022 at 05:25 AM. Reason: words |
What hold the axles in the rear end?
Are they held by plates on the backing plate?
Yes and the bearing on the axle is not a taper bearing.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 01-15-2022 at 10:58 AM. Reason: words |
I would say you have it right.
Treat this like a wheel bearing. The plates that bolt to the backing plate will need to be shimmed, So that left and right axle has minimum clearance in between them. If to much the axles will (walk around) slide back and forth. If not enough clearance the bearing plates will not be seated to the backing plate. Does it only have 1 bearing?
#7 | |
I will let all know when I get the Motors if it tells. As far as removing the hubs and knowing of consequences:
1) Removed cotter key and axle nut. 2) Shot hub/taper with liquid wrench 3) Next day used blue flame on hub near taper 4) Used a 3/4" thick strap across castle nut on axle left a little over 1/16" gap between nut and hub using 1/2" fine thread bolts across 2 opposite lug threads -- they are 4 lug 5) Slowly somewhat evenly tighten bolts -- need some tension 6) If needed give strap a light tap but was not needed. Both sides acted the same. 7) Do not gorilla anything. Use more liquid wrench and blue flame. As I understand most of these hubs crack because of the incorrect installation of the square key on the taper then tightening. Since they are 1/4" keyed I used never seize on the tapers to reinstall.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
