Old 01-31-2022, 07:39 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Need Help with Grommet
Does anyone have a part number for the grommet that goes in the hole where the spark arrester goes. Its the bottom left hole in the picture.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-31-2022, 09:13 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Need Help with Grommet
I think the flame arrestor takes the same grommet as the PCV. Looks like 3989347 for a 72.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-31-2022, 09:55 PM   #3
Already Gone
Thanks forte info. Putting 3989347 into Rock auto search it comes up with SMP GV20 and Dorman 42323 which I have but was having a toughtime getting it into the hole. Are these normally super tight when getting installed.
Old 01-31-2022, 10:07 PM   #4
Jason Banks
Jason Banks's Avatar
If you measure the ID of the hole in the valve cover and the OD of what you are sticking in it. You can find a universal grommet on Summit. Or post the dimensions and I'll look for you...
Jason Banks is offline   Reply With Quote
Old 01-31-2022, 10:14 PM   #5
Jason Banks
I meant to add. Yes, they are usually tight, use lubricant. Silicon grease or Dielectric grease...
Old 02-01-2022, 12:26 AM   #6
mr.mud1
mr.mud1's Avatar
i have them here,just installed 2 in my 72 big block valve covers,same grommet for the flame arrestor and pcv.i imagine a small block is the same grommet.they push in a little tight,i wet mine in the groove and helped them in carefully with a tiny screwdriver.
mr.mud1 is offline   Reply With Quote
Old 02-01-2022, 12:45 AM   #7
Already Gone
Thanks everyone. Went and looked on engine in garage and yes I have the right ones and will just need to need to lube and work em to get them installed.
Old 02-01-2022, 12:49 AM   #8
Already Gone
Did you get them at a GM dealer in Canada or get them in from USA.
Old 03-27-2022, 06:34 PM   #9
Thealien
Thealien's Avatar
I need a couple of those what is the part number on that bag.
Mark
Old 03-27-2022, 08:35 PM   #10
Already Gone
Mark
Part Number is 3989347 and I just got some in from Rock Auto
Old 03-28-2022, 07:51 AM   #11
Thealien
Thealien's Avatar
Thank you for the number and to check rock auto.
Old 02-01-2022, 02:54 AM   #12
71CHEVYSHORTBED402
I think I heated mine up with a blow drier and they popped right in. Whatever works.
Tony
Old 06-13-2022, 06:02 PM   #13
schovil69
I bought the Doorman 42323 grommets for the '70 SBC valve covers I'm working on. The inside diameter of the hole in the valve cover is 0.930". The outside diameter of the 42323 grommet is 1.25".
Are you guys actually getting this grommet to fit?
schovil69 is offline   Reply With Quote
Old 06-13-2022, 07:18 PM   #14
pjmoreland
pjmoreland's Avatar
I believe Dorman 42052 is the grommet that works with the spark arrestor. EDIT: The PCV and spark arrestor grommets have the same I.D. (I checked mine). Some PCV grommets are angled, whereas this spark arrestor grommet is straight.
https://www.dormanproducts.com/p-260...met&origin=YMM
pjmoreland is offline   Reply With Quote
Old 06-14-2022, 12:01 AM   #15
dmjlambert
dmjlambert's Avatar
Yes that is what I found also. I went and visited with an old timer at the parts counter at the Chevy dealer in Plano TX. He ordered the breather grommet GM# 14091870 for me, and said the PCV uses the same grommet, or if I wanted to use the slanted PCV grommet from later year models it is GM# 3989350. He also sold me the later model years PCV valve with the right angle hose connection. I like that setup best with the slanted grommet and right angle PCV valve. I can use a plain hose and don't need the one that is molded to bend, and the hose doesn't stick up, it just lays flat. There are Dorman equivalents and Dorman grommet seems to me to be softer rubber and easier to install. I replaced the breather grommet with a Dorman after I wore out the GM one by taking the air cleaner spacer off a couple of times too many. This is for 1969 SBC 350 engine.
Breather/flame arrester grommet GM# 14091870 Dorman 42052
PCV valve slanted grommet GM# 3989350 Dorman 42062
PCV valve (right angle elbow type) GM# 6487779
Old 06-21-2022, 11:26 AM   #16
schovil69
Originally Posted by dmjlambert View Post
When I search online that part appears to be for 8 cylinder big block engines and 6 cylinder engines, not for small block 8 cylinder. Try the part numbers I gave in post 15, your local parts store or Chevrolet dealership if you have one nearby should be able to get them for you.
That's good to know. I have a 454 block fresh from the machine shop on the stand I'm just getting started on. I will use the 42323 with those valve covers.
The dimensions for Dorman 42052 are,
Inside Diameter: 0.728"
Outside Diameter: 1.204"
The dimensions for Dorman 42323 are,
Inside Diameter: 0.718"
Outside Diameter: 1.403"
I think what has been most confusing for me with this is I didn't realize the advertised outside diameters are not the outside diameter of the grommet groove that sits in the hole of the valve cover. The advertised outside diameter is referencing the outermost diameter of the grommet. So, when I saw post 15 and looked up the number only to find a grommet with the same outside diameter as what I already had, I just ignored it. Unbeknownst to me, though, is what I just stated. That being, my measured-in-the-groove outside diameter was being compared to the overall outermost diameter of the grommet in my mind.
Knowing what I do about the 42323 with its measured-in-the-groove outside diameter at 1.2" and its advertised outside diameter of 1.4", I would suggest the 42052 with its advertised outside diameter of 1.2" will be spot on for my application in a 0.9" valve cover hole expecting its measured-in-the-groove outside diameter to be approximately 1.0".
Thank you dmjlambert for directing me to have another look, don't think I would have connected all the dots if you hadn't.
Thank you to all you guys as well for helping me figure out this issue. I'm still in disbelief that a guy who builds engines with his eyes closed had such a difficult time with the lowly grommet.
Old 06-14-2022, 12:53 AM   #17
Warrens69GMC
Warrens69GMC's Avatar
I usually add a drop of oil to the base and fold it like a Pac Man to get it in....
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-14-2022, 11:50 AM   #18
schovil69
Thanks for the responses to my question. I need to ask for clarification, though. Those Doorman grommets have an outside diameter that is more than a quarter inch larger than the hole it is meant to fit into.
For those with the approximately 1.2" outside diameter grommets fitting them into a 0.9" hole? That's 0.30" which appears to be quite a large difference. I'm not sure, though, hence the questions. I'll cram it in there if it's meant to be, just doesn't seem to be right.
Old 06-14-2022, 12:07 PM   #19
LNP
You can get these at a Auto Zone near you. The Proform part number is the same as the Acdelco number
https://www.autozone.com/engine/valv...set/751050_0_0
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 06-14-2022, 07:02 PM   #20
dmjlambert
dmjlambert's Avatar
Yes, cram it in there and it will expand back to the pre-cramming size once the metal is in the groove. Then insert PCV valve or flame arrester or breather tube.
Old 06-14-2022, 01:59 PM   #21
697498chevy
I also had a hard time finding this grommet for my 1969 307 . NAPA 630-1038 worked for me . HTH
697498chevy is offline   Reply With Quote
Old 06-16-2022, 09:24 AM   #22
schovil69
Thanks everyone. I'll get 'em crammed in there.
Old 06-20-2022, 03:32 PM   #23
schovil69
...or so I thought I would get 'em in there.
I 'Pac Man'ed the grommet to no avail. Hard to see in the photo but the side of the grommet opposite my thumb is in the valve cover hole and right at the 'Pac Man'ed part of the grommet is the side of the valve cover hole.
The overhead view with the grommet over the valve cover hole shows the inside diameter of the grommet in line with the valve cover hole on the right side. That's the inside of the grommet hole lined up with the valve cover hole. It's supposed to be the outside of the grommet groove in that hole...much grommet overlapping the valve cover. You can see the left side of the valve cover hole along with the amount of grommet overlap.
There's no way on God's green Earth that grommet is getting in that hole AND returning to a useful round shape.
So, I will find the proper grommet for this application and let you know.
Old 06-20-2022, 03:37 PM   #24
pjmoreland
pjmoreland's Avatar
What is the part number of your grommet?
Old 06-20-2022, 11:55 PM   #25
schovil69
These are Doorman 42323 from Rock Auto.
