02-01-2022, 07:07 PM | #1 |
Oil Pressure Line
I’m curious about the oil pressure line on the 72 Blazer that I am rebuilding. The oil line has a rubber casing around it, while my 71 K1500 oil line is just bare copper line. Both have a sbc 350. Are both correct for their year?
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
02-01-2022, 07:38 PM | #2 |
Re: Oil Pressure Line
I have had a couple of Blazer’s and Jimmy’s with the rubber coating around the copper oil pressure line. I’ve also had a couple without it. Who knows what happened over the course of the last 50 years? But I do believe at least some came factory with the rubber hose covering the copper line?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
02-01-2022, 09:09 PM | #3 |
Who Changed This?
Oil pressure lines, iirc, are steel from the factory. Copper work hardens and gets brittle and cracks. I suspect that the cover is to stop corrosion and/or nicks. If I ever replace my oil pressure gauge tubing, it'll be with a wire. The truck has had one engine rebuild and still has the original line, as far as I know, though.
02-01-2022, 09:34 PM | #4 | ||
The Older Generation
This is not always true. The refrigeration copper tubing that I use for my oil lines does not work harden. It is specifically made for refrigeration applications where there is a lot of vibration and other movement.... Quote:
LockDoc
02-01-2022, 10:39 PM | #5 |
LockDoc is correct this is known as annealing a heating/cooling process that gives copper ductility, annealing is also used in electrical wire manufacturing to make it flexible
02-01-2022, 09:44 PM | #6 | |
02-01-2022, 11:50 PM | #7 |
I don't recall any of mine having a rubber coating, but I can't say for sure that they didn't.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-02-2022, 12:11 AM | #8 |
I have original steel lines with and without the rubber sleeve. Also, some lines were one piece and some were two piece with a union connector in the middle. It may have been dependent on which supplier supplied the oil lines for a certain assembly plant. LockDoc
02-02-2022, 03:02 AM | #9 |
Rubber around the oil pressure line is common on 1973 and later years... I do not know when it was introduced.
I do believe it serves as vibration dampener. In my experience, less engine noise is transferred into the interior of the vehicle when used. Bob |
