02-03-2022, 03:06 PM | #1 |
Active Member
Help...Help...
When I plug in my headlight switch in it drains my battery over night.
Anyone have an idea why? |
02-03-2022, 04:43 PM | #2 |
Re: Help...Help...
If your light wiring is unaltered, no relays, warning buzzers, etc, Check to be sure the dome light isn't turned on.
02-03-2022, 06:21 PM | #3 |
Active Member
Re: Help...Help...
02-03-2022, 05:22 PM | #4 |
Re: Help...Help...
Possibly a short in floor dimmer switch.
02-03-2022, 06:23 PM | #5 |
Active Member
Re: Help...Help...
02-03-2022, 06:34 PM | #6 |
Re: Help...Help...
Time to get out your multimeter and chase down one of the well done schematics on this site!
You can do a parasitic draw test, to isolate which circuit may be causing the issue, and would also help isolate a lot of other potential draws. There's write ups to search if you don't know how. Do check the basics like grounds though. Are all the ground straps in place, clean, and making decent connections. Side note, Ford Explorers (can't remember the years) have decent push on ground straps under the frames, easy to pull, and work like a charm on our trucks. |
02-05-2022, 02:46 AM | #7 | |
Active Member
Re: Help...Help...
02-03-2022, 06:40 PM | #8 | |
Re: Help...Help...
Before we assume anything and go running down rabbit holes. Are any fuses being blown? Have you tried disconnecting a battery cable and jumpering a test light between the battery post and the cable? Do you know how to run this test?? |
02-05-2022, 02:44 AM | #9 |
Active Member
Re: Help...Help...
No fuses are being blown, and no I don't know how to conduct that test.
02-05-2022, 12:33 PM | #10 | |
Re: Help...Help...
https://www.bing.com/search?q=12+vol...&ocid=msedgdhp The easiest way to conduct this test: Disconnect either battery cable from the battery. Connect the test light between the cable and the battery post. plug in the headlight switch but don't turn it on. make sure EVERYTHING electrical is turned off. If you have a drain, the test light wil glow. The brighter the glow, the heavier the drain. If the test light is glowing (no matter how bright), one at a time start removing fuses. Pull a fuse and if the test light continues to glow, move on to the next fuse. When you remove a fuse that causes the test light to go out, that's the circuit that produces the drain. Areas to pay special attention. Dome light, glove compartment light, bad, or turned on dome light switches, sound systems, horn relay, relays that are not stock (factory installed). Come back and tell us what you find. We'll tell you what to do next. |
02-03-2022, 06:30 PM | #11 |
Re: Help...Help...
How old is your head light switch?
02-05-2022, 02:48 AM | #12 |
Active Member
Re: Help...Help...
02-05-2022, 03:06 AM | #13 | |
Re: Help...Help...
They weren't great new and often needed replacing multiple times in the lifespan of a truck. Moisture on your shoes, plugged vents that rust rockers right next to the switch, and many years can cause corrosion, high resistance, etc. In this case I'd replace the dimmer for peace of mind and being relatively inexpensive However, I also wouldn't rule out a cheap or defective replacement headlight switch either... and that's one reason I hate just throwing money at s problem without confirmation. Definitely learn some basics with a multimeter. You don't have to completely understand why you're doing a given test, and can still be very effective at narrowing down electrical gremlins. |
02-03-2022, 06:33 PM | #14 |
Re: Help...Help...
whatever is drawing the power and shorting to ground is getting warm or hot. Leave it on for five minutes then feel around and find out what is drawing power.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
02-05-2022, 02:47 AM | #15 |
Active Member
Re: Help...Help...
02-05-2022, 11:16 AM | #16 |
20' Daredevil (Ret)
Re: Help...Help...
You can use a test light instead of a VOM if you're more comfortable with it. Pull a fuse (or open a connector) and close the gap with a test light. If it lights up, even dimly, there's your current draw.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-05-2022, 11:28 AM | #17 |
Re: Help...Help...
Had a thought, check headlight switch to make sure it is not twisted to turn on the interior lights. Other than that it is time to check for draws associated with the headlight switch area.
