Old 02-07-2022, 10:40 AM   #1
scottmitchellrose
70 k10 front problems
2 years into trouble. replaced wheel bearings twice but she keeps eating them- causing the steering to pull to the right magically- dangerous. I have an 85 from axle i picked up for 300 (disc brakes). rather than swapping the whole axle, can I just replace it from the 'knuckles' on out? or is it best to just swap the whole thing- ball joints, etc. will not line up? Any videos or tips on such a swap? I think I need a different booster, master cylinder and portioning valve. Any recommendations for that setup too? Thanks a lot.
scottmitchellrose is offline   Reply With Quote
Old 02-07-2022, 10:41 AM   #2
scottmitchellrose
Re: 70 k10 front problems
oh- and will the hub knobs/ spring/ locks work on the 85 or are they different from the 70?
Old 02-15-2022, 05:45 PM   #3
duallyjams
duallyjams's Avatar
Had the same problem. I tried replacing with a used one off of a spare rear that I have but had the same problem, the bearing did not have a tight / snug fit, luckily the aftermarket world has plenty, replaced with a new one, problem solved.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-16-2022, 10:03 AM   #4
scottmitchellrose
[QUOTE=duallyjams;9035302]Had the same problem. I tried replacing with a used one off of a spare rear that I have but had the same problem, the bearing did not have a tight / snug fit, luckily the aftermarket world has plenty, replaced with a new one, problem solved.
thanks a lot- that spindle in the photo- it will fit a 1970 (drum) k10? where did you get it?! Scott
Old 02-16-2022, 10:09 AM   #5
duallyjams
duallyjams's Avatar
[quote=scottmitchellrose;9035534]
It's for a big bearing disc brakes. I bought it off of Ebay.
James
IG duallyjams
Old 02-16-2022, 05:16 PM   #6
61K10
61K10's Avatar
Scott---go to the 60-66 forum and the build section--search for 61k10 build. all the info toward the end (disc on the closed knuckle). New spindles from Yukon-hubs from Rockauto. they are big bearing spindles and hubs.
All the outer stuff of the 85 will be the big bearing stuff. It's all in my build--good luck
Kimble
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-03-2022, 04:29 AM   #7
Richard
RuffStuff has small and big bearing spindles for the Dana 44.
Big bearing https://www.ruffstuffspecialties.com/R2590.html
Small bearing https://www.ruffstuffspecialties.com/r2573.html
Richard
