12-30-2003, 12:51 AM | #1 |
DAMN, I love Big Blocks!
Painting Aluminum Intakes
I've noticed a few of you have painted your aluminum intakes. I have an Edelbrock Performer that will be going on my 454 when I rebuild it in the spring, and I want to paint it engine color. The problem being, I know paint does not stick well to aluminum. Anybody have any recommendations as to a product or procedure that will help the paint adhere permanently ?
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. |
12-30-2003, 01:06 AM | #2 |
Professional Grade
some sort of etch primer?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-30-2003, 01:07 AM | #3 |
I have the RPM Performer, all I did was clean mine with alumi-brite. Then rinsed it let, it dry off & painted it with no problems. Havent had any paint come off yet and that was well over a year ago.
12-30-2003, 02:14 AM | #4 |
get it powder coated if you can afford it.
1984 C10 SWB Custom Frame Blow Through Carb Single Turbo Hope to be on the road by Summer 2018 1967 C10 CST LWB 327/PG Original Running Driving Future Project |
12-30-2003, 02:34 AM | #5 |
5 day ban, learn to behave.
Is the intake new? If its used, just clean it real well. Bead blasting it would be ideal, but if you cant, then clean the hell out of it..
I think paint sticks to the porous, rough cast finish better than anything.. If you use a good engine paint like that 500 degree stuff, and put several thin coats, it will hold up well.. I wouldnt even primer it mike |
12-30-2003, 02:59 AM | #6 |
Thanks for the replies, guys! As always, you're the best.
12-30-2003, 03:35 AM | #7 |
Iamnotanofficerofthelaw
Watch out though, that Dupli-Color 500* and 1200* paint isn't gas and oil resistant. Although it says so on the can.
I sprayed a Briggs & Stratton gas tank with the 1200* stuff. I coated it pretty thick, the carb leaks and ruined the paint. If you look at my avatar (thats the engine) it's nice and shiny, I took a wire wheel to it cause of the damn paint. Powdercoating is very nice. Shouldn't cost too much, maybe $50. That's what i'd do, unless you can find a paint that's truely gas and oil resistant. But why should the carb be leaking anyways?
~Paul~ '96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock '87 S-10 Ext Cab- 2.8L/700r4 KIA Caught fire 12/7/03 Last edited by Big Paul; 12-30-2003 at 03:37 AM. |
12-30-2003, 04:53 AM | #8 |
I use plastic coat...make sure its very clean
75 GMC C-15 short/step factory 454, lowered |
12-30-2003, 03:35 PM | #9 |
The full convertible guy
I once bead blasted an weiand intake and didnt paint it but just sprayed clear over it. Looked pretty cool and definitely something different..............sorry i do not have pics of it. I would agree though about powder coating it if possible.
Brad
2012 Kawasaki Vaquero (Lime Green) 2000 BMW 740iL 1995 Chevy ECSB riding on air 1975 GMC Jimmy 2WD lowered 4/6 1972 Chevy Trazer soon to be roadster 1965 Mustang 289/3 speed (friends dad bought it new) 1964 Chevy C10 (dad bought it new) |
12-31-2003, 01:49 PM | #10 |
www.73-87chevytrucks.com
I blasted and then epoxy primed my complete motor and then shot base coat/clear coat on it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-31-2003, 04:18 PM | #11 |
All this talk about powdercoating......I have a powdercoating system, but is there anywhere where you can get powderpaint in chevy orange? Or VERY close to it?
12-31-2003, 04:24 PM | #12 |
http://www.eastwood.com has Chevy Orange powder.
