Relocated Battery Wiring
Here is my plan for how to wire it.
From the battery, I’ll connect to a 135 amp circuit breaker with 1/0 gauge wire rated for 150 amps. This would give me some protection to the wire running from the bed to the engine and ensure I don’t exceed its capacity. Then continue with 1/0 to the engine compartment. I’d connect the 1/0 wire to a battery terminal stud mount rated for 250 amps. From this mount I would connect the existing wires (all 1/0 gauge already) that connect to my battery now (starter, alternator, fuse panel and stereo amp). I have a 100 amp alternator, my amp is max 400 watts and no AC. I do run a FAST EFI system with an electric pump. I’ve upgraded the grounds using 1/0 wire to the chassis and to the engine block. I’d add another ground to the frame from the battery once it’s in the bed. Does this sound okay? Any thing you would change? |
![]() Join Date: Apr 2016
Re: Relocated Battery Wiring
Normally some of the 12 gauge wiring going into the cab is unfused. At the points where you attach your 1/0 wire to the 12 gauge wiring, I would insert 6 to 9 inches of 16 gauge fusible link wire, to protect your 12 gauge wire. Fusible links are 2 wire sizes smaller (that is 4 gauge numbers higher) than the wire it's protecting.
#3 | |
![]() Join Date: Jul 2000
The kit uses 6 gauge wire and 175 amp fuses, but I used 8 gauge SXL wire and one maxi-fuse (100 AMP, I think) because the truck had a low amperage draw and 78-amp alternator. Not to mention the 6 gauge wire was a bear to route! The kit also includes a second fuse and fuse block that snaps on to the first one. Also, my connection to the fuse panel actually goes to a firewall-mounted stud first where the alternator sense wire is connected. that means the alternator tries to keep 14.2 volts at that point.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#4 | |
Thanks for the help guys. Adding another fuse seems like a good idea. Looks like I have a bit more planning to do.
I think a V8 starter can pull up to 250 amps or so. I think you need a bigger circuit breaker or none at all.
I think AAW, Ron Francis, et al would tell you that no fuse or breaker should be used between battery and starter.
Think of a fuse or circuit breaker as a fail-safe not to burn down your vehicle in case of an accident that may pinch a positive wire and ground rather than protecting your wiring.
And remember, too high of an amp rating for a short circuited wiring problem will burn the wiring at the area of lowest amp rating of wiring. |
Most cars and trucks don't have a fuse or circuit breaker in the heavy gauge wire from the battery to the starter. Secure the battery to starter heavy gauge wire really well along the frame rail and I think you will be fine.
I used a Painless kit a few times and there is a maxi fuse that protects the rest of the vehicle. |
Think about how many cranking amps does your battery have?
![]() Join Date: Feb 2016
I have owned several cars with trunk mounted batteries from the factory. None of them had a fuse or other kind of over current protection in the supply wiring to the starter motor. They were carefully engineered wire runs so the starter supply did not have any opportunity to short out. Either from vibration or heat.
A 350 Chevrolet will draw between 250 and 350 amps when starting. The wide range depends on compression, ignition timing and the actual mechanical condition of the engine and the starter. This link may help. https://www.motortrend.com/how-to/be...anking%20power.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 02-21-2022 at 11:00 PM. Reason: Bad information on my part. |
#11 | |
I=E/R So if voltage (E) deceases, current (I) decreases.
You are correct.
What I was thinking was in order to do the same amount of work at a lower voltage the motor would have to draw more amperage. I will edit the post. And I apologize for any confusion I may have caused.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
You may have been thinking less voltage = more current with something like an electric motor. I once had an air compressor wired for 120 volts that would occasionally trip a breaker.
It was a dual voltage motor so I was able to rewire it for 220/240 volts. It then drew approximately half the current to do the same work, and never tripped a breaker again.
