Anyone here running a dual battery setup?
![]() Join Date: Mar 2003
Re: Anyone here running a dual battery setup?
I am in my 91 Suburban. I am running an on board air compressor and will eventually have a winch bumper on the front, CB, Scanner, Dash Cam and have the trailer package and plan on towing a 24' trailer
No, I got the trays from the wrecking yard out of a compatible diesel truck and am wiring it myself with a continuous heavy duty RV solenoid for charging.
Factory set up RPO TP2 was not available on Suburban.
Be advised there are two kinds of 12V dual battery setups: The diesels got two batteries (standard) but they are wired together to help with starting. The optional TP2 setup has one primary battery, and an isolated secondary battery for campers, or running pumps or a winch or whatever, without running down the primary battery. You'll need to decide which direction you want to go. The third type would be 24V, which was CUCV only. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-27-2022 at 12:08 PM. |
Just here to tinker
![]() Join Date: Jun 2008
Easy way to remember: series doubles voltage/amperage stays the same
and parallel doubles amperage/voltage stays the same. My ‘78 factory diesel had two battery set up in parallel for the extra cranking amps needed to turn over a 22:1 diesel. The early diesels had to crank at like 750rpm or they wouldn’t start.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
78 Big10 454
![]() Join Date: Jul 2008
I have a factory dual battery set-up. It is wired in parallel. Aux battery is wired positive to main battery positive. Main battery negative is grounded to engine block. Aux battery negative is grounded to the frame.
1978 Chevy SWB C-10 2WD 454/400 |
So from your main battery positive there are two red positive wires. I wonder what the dual cable looks like from the factory. Does your setup use the stock positive battery cable that came with all squarebodies?
Next!
My K30 Diesel Dump has a factory dual set up. ALL of the CUCVs were dual battery also,
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
As mentioned, the CUCVs came with a dual battery setup. Two batteries in series to give a 24V starting circuit. Almost everything else kept the 12V setup normal on civilian trucks. Both batteries were on the passenger side.
wazzabie - are you mostly concerned with factory dual-battery setups, or are you also interested in an aftermarket option?
I've been using the Hellroaring system in multiple vehicles over many, many years and I can't say enough good things about it. It is not the cheapest option but I've found it to be extremely reliable and easy to install. You could build a less expensive system using a Cole-Hersee relay, but the solid state system with install kit has been worth it to me. I purchased an aftermarket battery tray rather than hunting for something from a diesel or similar in the junkyard and it went in without trouble. The Hellroaring system provides me with peace of mind when I park a rig in the boonies and then don't return for many hours or even sometimes days. The auxiliary battery is being charged while driving but becomes fully isolated by the solid state diode when the engine is off. It is a great comfort to know the engine will turn over when it counts.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 Last edited by SilverMiner; 02-26-2022 at 11:34 PM. Reason: Fixed the Hellroaring link |
#12 | |
#13 | |
I have no experience with factory GM setups, but it was easy to discretely place the solid state box along the radiator support in a way that was hidden and could resembles a factory dual battery setup.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
The Hellroaring configuration I've used in all my vehicles (even the one without a winch but had a KICKIN stereo - over that now) is the BIC-95300B
Do check out their full web site, lots of good info and diagrams there.
#15 |
Just here to tinker
Maybe this could be an option for you:
https://www.bluesea.com/products/761...12_24V_DC_120A We use these in the boat world all the time. This unit will ensure you charge both batteries, but we’ll keep them isolated so you don’t accidentally kill your start battery when using the winch battery.
