02-24-2022, 11:22 AM | #1 |
Tie Rod Adjuster Sleeves
I'm looking to replace the tie rod adjuster sleeves on my 64 C10 2WD with the double adjustable tubular units from CPP. CPP lists one part number for 1960-64 and a different part number for 65-66. I would have bet the farm they were all the same. Does anyone know what the difference is? I want to be careful to order the right ones because returns are a hassle.
I'm making the switch because I'm not happy with the quality of the standard sleeves I installed a few years ago from a local parts house. |
02-24-2022, 12:54 PM | #2 |
Re: Tie Rod Adjuster Sleeves
Also interested in the reply to this one.
P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
02-24-2022, 01:03 PM | #3 |
Junior Member
I was looking at parts to rebuild my 63 frontend and found that the tie rods are different for 63-64, the outer tie rod is shorter so the sleeve is longer.
02-24-2022, 02:59 PM | #4 |
02-28-2022, 12:53 PM | #5 |
It's Better With Nitro
I run a tie rod adjuster that my friend machined with RH and LH thread more than 20 years ago. I think you can get these from most of the suspension suppliers/retailers like Western Chassis, POL, CPP, etc.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
07-22-2022, 04:32 PM | #6 |
A friend is working on a '63 Suburban and we figured out that 63-64 have around 8" sleeves , 65-66 are around 6" ? We're confused as well cause they're different than my '68.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
