Old 03-08-2022, 02:54 PM   #1
68 C10 Driver
Altman Easy Latch and Door Adjustment
So I installed the Altman Easy Latch and was really pleased with how it came out. I have fiddled with the door and just cannot get it to line-up with the cab.
The door is a reproduction door, so I know there will be some 'anomalies' in how it fits, but I want to get it as close as possible.
I will say, I temporarily installed the door seal (slip-on type) to see what effect it has. I can get the door in square, but the door from about 6 inches below the gas cap up to the drip rail is about 1/8" - 3/16" proud of the cab along the door seam. Being a repop door, I know that the fit isn't going to be perfect, but I would like to get it as good as I can get it.
Is this something I am just going to have to live with? The truck by no means was assembled with precision...there are several build mistakes that I have corrected, but a couple I have not due to the complexity of the repair. I have just decided to leave those.
Any ideas/thoughts are welcome. Here are some pics of what I have:
68 C10 Driver is offline   Reply With Quote
Old 03-08-2022, 04:40 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Altman Easy Latch and Door Adjustment
Watch this video from Stout Customs , it should help .
https://www.youtube.com/watch?v=Zvw5RhbhPVc
Old 03-08-2022, 05:33 PM   #3
68 C10 Driver
Thanks Grumpy, I will give that a try. Hopefully that will resolve the alignment and amount of force needed to close the door completely.
Old 03-09-2022, 01:33 PM   #4
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I have the altman latches and one repop door. Mine also fit like yours near the gas filler. Everywhere else was good. With a lot of work it was able to be adjusted and massaged to fit better during paint and body.
My doors do not close and open as effortlessly as I had hoped. Still slamming them and they are hard to open from the inside. It has gotten better as the seals broke in but still not what I had hoped for. If you find a fix let me know.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-11-2023, 01:52 PM   #5
jimijam00
Did you get them fixed so you don't have to slam?
jimijam00 is offline   Reply With Quote
