Old 03-08-2022, 09:05 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
A/C compressor - Seeking Edgeucation
I'm working on a rebuilt original A/C system, getting ready for a maiden start soon. I have all the connections figured out, o-rings and such. I'm leaving the connections snug only for a pro to tighten things up.
I'm wondering if it's A-ok to connect the compressor belt so long as the A/C isn't run? It will be charged with R134A after the truck is running.
I've never tensioned an A/C belt before. Near as I can tell I can do that with a pry bar against the compressor and its lower bracket, but is there a cleaner way to accomplish this?
Thank you
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 03-08-2022, 10:07 PM   #2
Richard
Re: A/C compressor - Seeking Edgeucation
No problem putting the belt on. The compressor will not run unless the clutch is engaged. For extra insurance if controls are on leave the wiring disconnected to it. With no charge in the system the low pressure switch would prevent compressor from coming on as well.
Do not know of any other fancy way to tighten the belt. Maybe wrap your choice of pry tool with a rag to try and save your nice paint.
Richard
Old 03-09-2022, 10:55 AM   #3
mr.mud1
mr.mud1's Avatar
hi Tony,i just did what you're asking,my system will be charged after the truck is running.i left the wires to the clutch off and took a long pry bar with a rag on the end,down behind the compressor til i got to the head near the exhaust manifold and pulled it tight,unlike the previous owner or whoever worked on it,put a bar down on the valve cover and pulled,smashing in the valve cover.with a long bar,you won't have to pull very hard.take care.Greg
mr.mud1 is offline   Reply With Quote
Old 03-10-2022, 10:53 AM   #4
Davidf
I do not believe a factory a/c setup has a low pressure switch.
To the OP: Avoid over tightening the belt as that just puts undue pressure on bearings. Why leave the tightening of the fittings to a pro, nothing magic about tightening up the line fittings...just don't be a gorilla. If are converting to R134a, did you flush the system to remove all the mineral oil? Are you upgrading the condenser? If you leave the line fittings loose, you risk allowing moisture into the new (assumption) receiver/drier. Not the end of the world, but will require a longer evacuation time to boil out all the moisture and dry the desiccant.
Davidf is offline   Reply With Quote
Old 03-13-2022, 08:40 PM   #5
71CHEVYSHORTBED402
Yeah maybe I'll tighten things up after it's assembled. My instinct was per the torque setting, I don't have the tool gauge, but the pros probably torque to feel anyway.
The entire system is rebuilt for 134a. Installed the compressor. I'm a brake brake booster away from finishing the bay for fenders. Long haul.
Tony
Old 03-09-2022, 08:26 PM   #6
71CHEVYSHORTBED402
Darn previous owners............
Thanks a bunch for the info.
Tony
