03-12-2022, 12:54 AM | #1 |
Routing 6 gauge charging wire to Alternator
Evening folks,
How did you guys route your red 6 gauge wire from the starter to the alternator? I am trying to keep everything hidden, yet practical, and am having a hard time just doing it. Any suggestions and/or pics would be greatly appreciated. I scoured the site for past posts but didn't find anything this specific. Thanks!
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
03-12-2022, 02:47 AM | #2 |
Re: Routing 6 gauge charging wire to Alternator
My truck has headers. I went in from the front of the motor to the starter. There is a small bracket that retained the wire on the top frame rail. I may have re-positioned it a little forward, I am not 100% sure of that. Then from the starter to the alternator by running the wire behind the block. I have to admit it is tight between the block and the headers in this locale. Then it was ran on top the block in a plastic loom with the other wires. I was very happy with the results. I'll get you some pictures tomorrow. It is hidden pretty well and I don't consider it view any more than if I had gone the other way to the frame rail. I also recommend a side post battery. It cleans up the battery looks a lot in my opinion. It as has the cables going in the right direction with out much of a bend unlike the 90 degree that would be required with a top post.
Another option is to run the wire like the 2000's Silverados. They have the battery on one side and the alternator on the other. The cable is run under the cross-member below the radiator. This is a separate wire from the starter wire on the Silverado. Last edited by Accelo; 03-12-2022 at 10:44 AM. |
03-12-2022, 11:48 AM | #3 |
Thank you Accelo! I look forward to the photos. I will post some of my set up as it is not conventional at all.
03-12-2022, 04:33 PM | #4 |
I didn't run the alternator output to the starter when I converted my alternator as I wanted to avoid the voltage sensing issues explained in this link from Mad Electrical. If you haven't visited their site I recommend it, as they have a lot of good technical information posted.
http://www.madelectrical.com/electri...evymain1.shtml However here is a link on how I did my conversion and there are links available in the posts to sites I gathered information from. Scroll to post 467 start. http://67-72chevytrucks.com/vboard/s...698377&page=19 I hope this may help.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-12-2022, 05:54 PM | #5 |
On all my LS swaps I come off the starter lug, around the front of engine using a few of oil pan bolts and rubber lined metal cable clamps to secure. I've never had any sensing issues running it that way.
I too like to hide wires. Here's a pic during the build. Bit hard to see. |
03-13-2022, 11:25 PM | #6 |
LS Short box, do you have any close ups of your lines being routed?
03-14-2022, 04:42 PM | #7 |
Sorry I don't.
03-15-2022, 01:57 AM | #8 |
Ttt
