Old 12-30-2003, 04:06 PM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
lowering blocks
will lowering blocks hurt the handling of my truck. I have already put a 2/4 drop on it and i would like to drop the back another inch or so to level it
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 12-30-2003, 06:38 PM   #2
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
well, if you go another inch (total of 5" drop in rear), you will most likely want to use some alignment shims to adjust the pinion angle of the rear end. at ride height, chek the angle at the trans end and at the yoke on the rear to get the angles. 2-4 degrees is what you want. of course, this is assuming that the driveshaft is level. you may be ok without them, but it never hurts to check and double-check. good luck!
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 12-31-2003, 02:12 AM   #3
PR454SS
PR454SS's Avatar
Shamrock is right on with the shims, mine is dropped 5" in back and I had to add 2 degree shims to get it back within specs, also need to get an adjustable panhard bar if you don't already have one
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 01-09-2004, 12:43 PM   #4
sactoC10
71 DELUX
sactoC10's Avatar
I use 3" Eibach rear drop springs and have 1.5" of drop with blocks and all is well. When I had 2" of additional rear drop with this combination, I could feel the drivetrain struggling a bit, so you'll need shims at 5" in my opinion. I need to get some before going back down to 5" total.
JT
sactoC10 is offline   Reply With Quote
