Old 03-15-2022, 09:51 PM   #1
67K10longbed
Anyone building SM420's near Pittsburgh?
I think I found the main shaft and coupler to fix my SM420. I have it partially apart , but without a press I am stopped. I am not sure how to get it apart from here. I would guess the 3rd needs pressed off? I am going to do some more reasearch , but in the meantime is there anyone in Pittsburgh , Pa area that rebuilds these? This is where I am with the trans.
67K10longbed is offline   Reply With Quote
Old 03-16-2022, 08:08 AM   #2
MJN
MJN's Avatar
Re: Anyone building SM420's near Pittsburgh?
You need to remove the entire main shaft assembly to remove the gears. If you have a service manual it has clear steps on disassembly. I rebuilt mine last spring with no special tools or issues, I used a rebuild kit from Novak Adapters.
If you need a service manual you can download a pdf copy here
http://67-72chevytrucks.com/vboard/s....php?p=5781194
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 03-16-2022, 08:28 AM   #3
HO455
HO455's Avatar
As MJN stated the SM420 is an easy transmission to rebuild and Novak is a great vendor.
Since your already that far might as well go all the way. This video link may be helpful.
And Welcome Aboard.
https://youtu.be/6imX-_msbo8
RIP Bob Parks.
Old 03-16-2022, 09:08 AM   #4
67K10longbed
Thanks, I will take a look.
