Old 03-19-2022, 09:11 AM   #1
bcoke
Gauge Cluster Issue / Replacement
My 72 K5 has had a ton of electrical gremlins ever since I got it 6 years ago. The previous owner did a lot of custom wiring (speakers in the door, remote locking, not to mention the engine swap) so it’s a rats nest of wires under the dash.
Yesterday I started the process of what I’m guessing will end up being rewiring the whole truck, and I took off the gauge cluster to get better access. The gauges haven’t been super accurate - mileage is maxed out, speedo is all over the place, I don’t trust the fuel gauge. Plus when I took it off there was some rattling inside the housing.
I thought this would be a good time to replace it with modern gauges that look classic, but as I looked around it seemed like the going rate for anything decent (Dakota digital / classic instruments) was $1000. Cheapest I could find was $400, but that had a lot of bad reviews saying it stopped working.
1. Am I missing anything? Any ideas on where to get solid restomod gauge cluster replacements besides those two places I listed and googling around?
2. Anyone know how I could repair my current cluster or who I could send it to for repair? (I’m in TX)
3. Not having accurate gauges isn’t the end of the world - I definitely need to prioritize having the engine turn over reliably haha so is there any downside to leaving it as is while I get the wiring sorted out? I figure I can always replace it down the road without too wiring hassle again…
bcoke is offline   Reply With Quote
Old 03-19-2022, 09:33 AM   #2
hemi43
hemi43's Avatar
Re: Gauge Cluster Issue / Replacement
You get what you pay for, and purchasing my Dakota Digital gauge cluster was one of the best things I did.
hemi43 is offline   Reply With Quote
Old 03-19-2022, 09:35 AM   #3
jaros44sr
jaros44sr's Avatar
I would start with a new harness from M&H, great customer service, and answered all my dumb questions
Plug and play,some of you gauge problems may clear up, and you won't have to worry about an electrical fire
Nothing wrong with the stock gauges and there are forums members to service them.T bone comes to mind, but there are others
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-19-2022, 05:51 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Keep it simple. I’d put some elbow grease into cleaning the OEM cluster. It’s possible that the issues w cluster are upstream from the gauges. For example maybe the speedo cable needs a clean and lube, needs replacing, is loose at one end, or not seated well at the t-case. If the fuel gauge is off it might be the sending unit.
gauge, gauge cluster, gauge replacement, gauges, wiring
