03-22-2022, 03:16 PM | #1 |
Long stepside bed to Shot
Hello guys,
I need help here. I have stepside long bed for 1979-87 and I want to make it shorter to fit my C10 1978. Anyone has exact measures and where to cut & if possible a guide or drawing will be awsome. P.S: shortbed is not available here and would cost fortune to bring from USA. Thanks Posted via Mobile Device |
03-22-2022, 11:21 PM | #2 |
Re: Long stepside bed to Shot
Doesn't look like rust is a problem where you are, ha. This thread might be helpful.
http://67-72chevytrucks.com/vboard/s...d.php?t=541190 Generally speaking shortbeds are 6.5 feet long, I believe. Someone might chime in, otherwise I might remember to measure mine for you. No reason to overthink it: just measure five times and cut once, and do so to fit it to the 1978. And order a couple new "steps" for a shortbed.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
03-23-2022, 04:20 AM | #3 |
I should be able to get ya something later today, I've got a couple short sides in the basement.
03-23-2022, 08:14 AM | #4 |
This might be all ya need to get started. first pic
Front lip to the center of the lowest fender bolt hole. http://67-72chevytrucks.com/vboard/a...1&d=1648037304 Second pic, rear lowest fender bolt hole to the tailgate stop. http://67-72chevytrucks.com/vboard/a...1&d=1648037362 Overall length of bed rail is 80 3/16" Let me know if ya need more info. |
03-24-2022, 02:29 AM | #5 |
Thank you for the pictures but if possible, could you please take a photo of the whole bed side with measures from fender holes to front and rear edges so I can know how much should I cut.
03-24-2022, 02:33 AM | #6 |
Is that not what I gave you? I don't know if I have room to get it all in one pic. I'll see.
03-24-2022, 03:16 AM | #7 | |
03-24-2022, 03:39 AM | #8 |
I'll see what I can do. But let me ask you, what are the dimensions of you long box compared to mine?
03-24-2022, 03:50 AM | #9 |
I will measure my neighbor’s and take some pictures.
Mine is 400 miles away but they are identical. Posted via Mobile Device |
03-24-2022, 05:36 AM | #10 |
Got those measured!
Hope they help See attach please Posted via Mobile Device |
03-24-2022, 12:31 PM | #11 |
Ok, I tried to copy your pics with my short bed. When you're ready to mark it out to cut I can spend some time with ya getting it right. It looks like you'll be cutting off some in front of the fender and some behind it.
http://67-72chevytrucks.com/vboard/a...1&d=1648139384 http://67-72chevytrucks.com/vboard/a...1&d=1648139384 |
03-25-2022, 03:52 PM | #12 |
Travelled 400 miles to get the long bed, turns out the bed was covered by a welded steel plate & it seems I will be having a very long day taking it out.
The goal is to remove sides and make clean cut. Will see tomorrow, it’s 11 Pm here. Posted via Mobile Device |
03-25-2022, 05:35 PM | #13 |
That looks like it will be easy to shorten...when I did my IH bed I had to work around stamped areas of the bed...but it worked out great..
03-26-2022, 04:23 AM | #14 | |
03-26-2022, 04:29 AM | #15 |
Nice floor!
03-26-2022, 05:32 AM | #16 |
When you live in deserts, floor tiles is your only option 😏
03-27-2022, 04:32 PM | #17 |
It was a struggle to remove the 3 mm steel plate as it was welded to the whole sides, managed to save sides without too much damages.
04-10-2022, 07:27 PM | #18 |
Got both sides cut.
And awaiting bed steps to arrive as I have long once. Posted via Mobile Device |
