Old 03-27-2022, 04:10 PM   #1
Desert dog
'60 Apache 2WD front wheel cylinder bolt size
We're moving on to the front brakes and have run into a conundrum. The large bolt holding the wheel cylinder's in place appears to be an odd size. A 1" 6 point socket is loose and a 15/16" six point is too small. Is it possible this is a 31/32"?
My cursory calculations show that a 25 mm falls roughly between the two above mentioned sizes so I'm going to purchase one. It looks like
I'll have to grind the chamfer off of it though as the bolt faces are pretty shallow.
Any input would be greatly appreciated.
Regards,
Desert Dog
Desert dog is offline   Reply With Quote
Old 03-29-2022, 12:54 PM   #2
Desert dog
Re: '60 Apache 2WD front wheel cylinder bolt size
FYI. To answer my own question, the bolts appear to be 1". They measured .996" with a caliper.
That said a 1" was still too loose. So I purchased a 25mm deep impact and ground down the chamfer. It fit perfect . With a days soak from PB Blaster and a rattle gun they came right off.
Old 03-29-2022, 02:21 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Thanks for sharing how you fixed it! I haven't pulled one myself, so I didn't have the answer previously.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
