Old 03-28-2022, 12:42 AM   #1
Dodge68charger
Power Booster Rod Help?
I Bought a Tuff Stuff Power Booster and Captain Fab Bracket, Drilled The Hole An Inch Lower On The Pedal..
Am I Missing Something Because The Power Booster Rod To The Pedal Would Be On a Huge Angle
Dodge68charger is offline   Reply With Quote
Old 03-28-2022, 07:45 AM   #2
Peanut74
Re: Power Booster Rod Help?
Based on the picture I would use the top hole. That would put the rod more inline with the MC. Why did you drill the extra hole?
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 03-28-2022, 10:41 AM   #3
Dodge68charger
I Dont Remember Lol. Been a While.
I ll Use The Upper Hole But It’ll Still Be About An Inch Lower. Be On a Bit Of An Angle
Old 03-28-2022, 05:41 PM   #4
jessemthompson
If you use the upper hole and you don’t have brakes till the bottom of the pedal, move it to the lower hole. With the factory booster and bracket it has an angled rod right behind the booster. You need to have the correct brake pedal ratio. Otherwise things won’t operate correctly. I put in a universal booster with captain fabs bracket. I had to drill a second hole and inch lower in order to have a full pedal.
jessemthompson is offline   Reply With Quote
Old 03-28-2022, 08:34 PM   #5
Dodge68charger
How Bad Is The Rod Angle?
Same Deal, Aftermarket Booster n Captainfab Bracket
Old 03-28-2022, 10:40 PM   #6
pappy 2
I used original brake peddle hole with the Captain Fab flush mount addapter.
pappy 2 is offline   Reply With Quote
Old 03-29-2022, 12:30 AM   #7
Dodge68charger
Thank You
Old 03-29-2022, 06:45 PM   #8
Peanut74
I ordered my power master brake cylinder today but it does not come with the mounting bracket. Could one of you gents please post a link to Captain Fab's site, please. I know I'm going to need it and would ather use a proven design than come up with something on my own.
Old 03-29-2022, 06:53 PM   #9
BASE
BASE's Avatar
I guess he does have a site now:
https://customfab-cda.com/
'68 K10 496/465/205
BASE is offline   Reply With Quote
Old 03-29-2022, 10:38 PM   #10
Peanut74
Thanks BASE. I'll wait to order a set until I get my MC. Just to be sure the hole patterns match.
Old 03-30-2022, 05:57 AM   #11
BASE
BASE's Avatar
When I got mine I think he provided a list of compatible boosters, or recommendations. Might be worth an email.
'68 K10 496/465/205
Old 03-30-2022, 11:27 AM   #12
HalfBrit
Just placed an order for one of the brackets from Custom Fab, for my ‘70 C10 (appreciate the link, BASE). The bolt pattern measurement is 3-1/2” x 3-3/8”.
HalfBrit is offline   Reply With Quote
