Old 03-31-2022, 06:58 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
6L80e trans shifter spline thingy .....
What attaches to this shifter spline ? I have heard that the older style ( TH350) would work but cannot for the life of me figure out how....
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 03-31-2022, 10:36 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 6L80e trans shifter spline thingy .....
That looks like part of a Lokar adjustable shift lever. It should come off then the older lever will go on it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-01-2022, 07:57 AM   #3
Joyridin
Agreed. It looks like the Lokar adapter.
Joyridin is offline   Reply With Quote
Old 04-01-2022, 05:23 PM   #4
6600DURAMAX
Can't figure out how to get it off though ......
Old 04-02-2022, 07:59 AM   #5
Joyridin
The transmission shaft has 2 flats on it for location. My Lokar adapter has a screw int he center that holds the adapter in place. Your looks as though the screw is either missing or broken off in the threaded hole? My adapter is aluminum. Your looks to be more like metal, although it is hard to tell. If you remove the center screw on mine, the adapter slides right off the double flats.
Old 04-03-2022, 10:11 AM   #6
Accelo
Accelo's Avatar
Sometimes it takes a very thin wall socket to get this on or off. You may need to grind the OD of a socket to get it to fit.
Accelo is offline   Reply With Quote
Old 04-04-2022, 09:18 AM   #7
6600DURAMAX
Thanks guys, I'll give it another go today ....
