04-05-2022, 05:48 PM | #1 |
Looking for some help with venting.
I picked up one of the later year Suburban fuel tank vent tubes for my 67. I want to get away from the non-vented fuel caps that always seem to leak on hard left hand turns with more than 1/2 a tank of fuel.
One of the things I need is measurements as to where the factory installed them. I'd hate to drill a hole and find something in the way inside the rear quarter panel. The measurement can be inside the cab or underneath where the lines exit or in a perfect world both. My other dilemma is identifying the 3 lines. At some point in the past I found a thread identifying the 3 lines in the bottom of the tube but dang me if I can find it now. If memory serves me one line ends to near the top of the tube. One line ends midway up the tube and the last one ends at the very bottom of the tube. I'm sure the one at the top of the tube would go to the vent canister The other two I think go back to the fuel tank? I really only need the one at the top the canister and one on the bottom of the tube. I could fill the tube with water to identify the heights of the lines inside the tube but, I'm hoping someone here will have the information I need and save me some steps. The factory chassis manual shows the bottom line ( Line to the farthest right in photo) going to the canister but no information about if that is the highest line in the tube. Thanks in advance.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-05-2022, 07:01 PM | #2 |
Equal opportunity joke ofender
Re: Looking for some help with venting.
If no one else pipes in before then, I can get some pics and measurements off of the 72 I have sitting here in the morning
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
04-05-2022, 08:00 PM | #3 |
I changed over to a 40gal. tank and had the 2 vent lines added to the tank to use this same system. I used that same diagram to hook my lines back up.
Putting a tape measure in mine, there is a small upward bend at the rear I measured from. It's 9 1/8" to the first hole from the rear, and 2 1/8" from the outside to the center of the first hole. |
04-06-2022, 12:56 PM | #4 |
Here is what I have from this morning. I would need to pull the covers off if you need the size of the holes in the quarter panel.
04-06-2022, 02:13 PM | #5 |
Thank you very much gentlemen! Just what I needed.
Richard no need to pull things apart. The plate I have has the hole outline etched in rust on the back side. Not all rust is bad.
04-06-2022, 10:57 PM | #6 |
HO455, Now is the time to sound deaden and insulate if you are going to...I used 3" house insulation between my side panels and the sound deadener...
04-07-2022, 08:05 AM | #7 |
Be careful with house insulation. One of the suburbans I parted out was loaded with it and it had a leak in one of the windows. The insulation was totally soaked and had started rotting stuff from the inside out.
04-08-2022, 03:40 PM | #8 | |
Whatever product I use needs to stay intact and not absorb moisture. Originally I was thinking of using some carpet insulation but the product Beach-Burban used has piqued my interest.
04-27-2022, 08:16 PM | #9 |
I did some water testing and figured out which tube is which. See photo.
